Autoload a plugin with RR?
  • Autoload a plugin with RR?
    Hi ppl!
    I just have a verry simple question, is there anyway to start a plugin when RR starts... as it works now I have to go to it's screen everytime I want it to start...
    Swedish site for CarPC's
    http://www.bilpc.info
    which plugin ? extension plugins are auto-loaded with the skin if installed correctly. Application plugins would require you to load them manually.
    Ride Runner RR's Myspace
      Well it's the Milage plugin made by festy... discussed here in the forums...
      as it works now it doesnt start to record my milage info before I go to the screen for that plugin, sure it's not a big deal to go there before I start to drive but it would just be a lot easier if it started at the same time as RR...
        where the did you place the "X,<plugin name>" line ? it should be on MENU.SKIN otherwise it won't load till u open the screen you've added it to.
          It was the plugin's fault - even if you loaded it from menu.skin, it didn't 'start' until a label or cmd was called from the plugin. I hadn't noticed, as I had one of it's labels on menu.skin so it was starting straight away for me...
          It's fixed now, see the plugin's thread for a new dll.
            ohh... so you are sneaking around reading other ppls threads... just kidding, nice done...
