RR Extension Plug-In - RRFadeVolume
  • RR Extension Plug-In - RRFadeVolume
    I whipped up a PLUG-IN
    just add
    X,RRFadeVolume
    to your menu.skin, or plugins.txt or wherever your skin keeps em
    I did some updates to this while back...
    now that i did some work internally to RR audio, i might improve this
    its been a while, but i think i added ramp back up after un-mute!
    -Mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    You star.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
      mitch you are the man!
      Live mp3Car Facebook Chat
        I'm having some trouble with this and i've just noticed why...it's .net dependant!
        Just proves it doesn't it really,Be careful what you wish for.
        So it looks like you have me cornered Mitch,lol.
        So this net framework,do i actually need it beyond registering these objects?
        EDIT: No,Its not the framework that is the problem,just installed that and everything reg'd ok but it screws my audio up completely after resume.
        Very slow motion and very synthesized and seems to affect all of windows audio after rr is closed until rr is restarted
        EDIT 2: Even after i un reg your plugin this DEV pc keeps doing it so it's probably just an issue on this machine,i don't have cause to hibernate this 1 so i've never noticed it.
        I'll stick it in the car later and i'll let you know how it goes.
          I ONLY PROGRAM IN .NET, i dont program anything on a pc other then C#
          u did disable the "built-in" fadevolume?
          in rr.ini
          fadeinvolume=false
          mitch
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            Works great here. Thank you!
            The Car 2005 Scion xB
            The Truck 2004 GMC Canyon
              in rr.ini
              fadeinvolume=false
              mitch
              Yes i did,like i said i think its this pc but can't be sure till later.
                anyone out there using this?
                do i need to add/change anything?
                mitch
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  I never could get it to do anything, but I'm sure I was doing something wrong. I'm getting ready to start building my house, so I'm not really worried with it right now.
                    mitch
                    I am using it with no problems.
                      Still not got chance to test as the car's in for some work,will be back tomorrow so i'll get to it asap.
                      I can see trouble ahead though,this flash intro i'm running tries to mute winamp while it plays its audio clip then un pause and allow rr control of winamp,always seems to screw up,tried to troublshoot it a couple of times (special thanks to Sonicxtacy) and its more well behaved now but we couldn't find a bullet proof solution.
                      What actually happens is the pause/unpause gets messed up and rr pause's the track its trying to resume to,i think this being a seperate process is gonna compound the problem.
                      Anyway this has nothing to do with your plugin,i see no reason that it won't do what it says it will but i think that bloody intro's gonna screw it up.
                        If RR does this natively why do we need a plugin?
                        New Age Garmin - Skin for RR
                        New Age Slider - RR SKin In Progress
                        "It's called CODE because I don't want you to know"
                          thunder, it DOES NOT do it right!
                          it does it completly wrong, by a mix of mixer INPUTS and winamp volume!!
                          very very bad!!!
                          if you got xm, hd, sirius, or any radio for that matter,
                          and music resumes, the fade will screw up the mixer
                          course this only applies to my builds and 9/10 offical merge build
                          since they are the ONLY builds that resume correctly!
                          mitch
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            fadeinvolume=false
                            ^^ this just fixed my problem where my winamp volume would sometimes go to zero when I come out of hibernation. Woo Hoo! Of course I never had a problem like this before until I added HD Radio and latest RR version. I'll test out this plug in next as it's a nice feature to have.
                              just ran across this after doing a quick search on how to fix my volume fade issues...
                              works great!!!
                              thanks mitch!
