preview of my first skin " limelight"
  • preview of my first skin " limelight"
    this is a preview of a skin im working on
    its my first , in the center ima trying to get a clock but when i used the skin editor to put a flash file in it doesnt show up so i have to find a way to do that
    mainframe is based on the cfx skin
    but i went i with a very minimal look with less buttons
    looks good. I think the text should be a bit bolder.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
      I like your graphic design skills, but you seem to have two menus (LHS and centre - why?) it doesnt make any sense.
      maybe think about what you want first, how it will be laid out etc, scribble each screen down on an A4 sheet, and only then have a go at the Photoshop stuff.
        the left menu is visible thru many of slides of the skin ie gps, tv, mp3, apps, it will be what ties all the slides of the skin together, the one in the centre is the main menu when the front end just starts
          Nice design.
          Genesis Skin
          Bongo Skin
            Nice, but I think you need more contrast between the background and text or it may wash out in the car.
            So, pretty much
              ok i got the clock working, might have to change it to a different design, and i bolded up the text a bit
                Ummmm.....
                don't like the clock.......
                Seems out of place on a fairly clean skin, getting kind of cluttered. But I prefer the minimalist approach anyways. Just me, it's your skin bro, do as you like!
                Cheers
                BJ
                  Clocks to me are worthless. Especially in flash. RR has a time label you can add if a time display is wanted.
                  The status box at the bottom where it displays stop and other stuff seems to be a little squished along with the song title running in to it. Maybe creat a border around it and use smaller fonts. This would clean that up pretty nice I think. Otherwise keep rockin' it
                  New Age Garmin - Skin for RR
                    I can do you a custom version of my clocks where you can change the colours etc to match your skin. I can also remove the out ring if you don't want it.
                    More details can be found here - http://www.mp3car.com/vbulletin/show...=77153&page=27
                    Contact me by email / PM if you want to discuss.
                    Regards,
                    Steve
                    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
