Navigon Navigator 2.0 embedding in RR
  • Navigon Navigator 2.0 embedding in RR
    Hi all,
    Can someone please explain how to integrate Navigon Navigator 2.0 not the NCK 4 or 5 but Navigator 2.0
    Please tell me how I can adjust the screen size. There is no NCK.ini file in Navigtor2.0 When I try to load navigon.skin navigtor 2.0 starts but in full screen mode. I would verry much like to have navigon in RR embed. But at this moment I'm unable to do this. I'm trying hard. But nothing helps. Only full screen mode.
    Any suggestions? please.
    best regards,
    Osa2
    Yep - Point the gps exe in the rrconfig to the Navigator 2 one and then set the window name as 'NavigatoR'.
    There are settings with in one of the ini files how ever I cant remember which. These needs to be set to according to the external_gps.skn of the RR skin your using.
    I hope that helps.
    Terran
    My Project Site
      I did point the gps exe file in the path of rrconfig. The application does start. No problem at all. Only thing is it is full screen. So I cannot see any of my other RR buttons.
        Yep - thats the external program name 'NavigatoR' in the rrconfig.
        It does run - I've done it.
        Terran
        My Project Site
          No, I want something else
          I already had navigator to work. The thing I need is to embed navigator2.0 in RR. So that I am able to see the navigator programm application. And see RR skin file. So I can press a button from a .skin file
          That is what I want.
          Not to start navigator. That is standard external program link.
            Do you have a solution for your problem meanwhile?
            I have the same.
              Hi, Since this post was 3 to 4 years old a lot has changed to my carpc.
              I did manage to get the the screen integrated into rr.
              Although I can't remember how.
              But, you are lucky I kept all my wrinting down.
              So after looking into. It was in the navigator.ini
              You need to add
              [Dimension]
              Width=x
              Height=y
              Where X and Y are values off course 800 * 480 I guess (didn't wrote that down)
              Also when you need to position the screen use
              [Dimension]
              OffsetX=20
              OffsetY=10
              Just play around with the 20 and 10 to see how much they need to shift for your screen.
              That's it. Hope you get it working.
              I don't use navigator anymore since I could not buy a new licnese. And they have stopped making the version for use on laptops. Pitty because navigator is the best I have tested so far. Now I'm using PC navigator 10 from Mapfactor.
              Also pretty good but not as slik as navigator was.
                I work's!
                Thank you very much! :-)
                I tryed iGO aswell. The iGo-Window has the right solution already, but it isn't at the right position. And in the iGo folder there's no file like the navigator.ini
