BLACK & WHITE_APPLE 800x600 & 800x480 released
  • BLACK & WHITE_APPLE 800x600 & 800x480 released
    Skin no longer supported.
    Wow.....Nice skin! I'm toying with the settings on my PC & once everything's ok, I'll be using it in my car tomorrow
    Can I request for a Toyota Speedo (km/h) instead?
    Cheers!
    Intel D945GCLF2, Lilliput 629GL-70NP, GTop MTK GPS, Road Runner, DFX4, Winamp 5.13+Console+VST->HotAudio DAC->NXS 400.4 + NXS400.2 DSP Amplifiers + DSP Software Processing->Dynaudio 340 3 Way Active
      Wow, that looks very nice!
      My Fiero Build Thread
        Yes, very nice indeed. Keep up the good work.
        Alex
        Progress: 91% (Cosmetics) @ Stand Still...
        CarPC specs are BACK!! Edit yours today...
          thanks for your request.
          i thought this will be one of the closed threads... a hundreds of views without any critic... wishes... .
          i try the application in my car, its a 2,66Ghz with 521MB RAM. as i only open the coverflow screen, roadrunner need 100% of CPU speed, nothing else works.
          thats not what i want, so i will make a second possibility for selecting by ALBUMCOVER in normal way.
          or did i forget any selection.
            GF-ler,
            Thanks for the skin... It looks really nice. However, I am having problem getting a background to show. I have read the "how to install" file. This led me to look at the exectbl file, the general.ini (skin version), the skin.ini file (which has a background path pointing to a folder from your *old* path name -- ie: not iphone or night apple). Changing all these paths to my background path didn't fix the problem. Could I bother you for a clue of what I am doing wrong?
            Nasa
              Originally posted by nasa View Post
              GF-ler,
              Nasa
              hi,
              iam sorry, but something goes wrong between my install and the package NIGHT APPLE.
              FIRST:
              normaly its not important what name of skin you use.
              only in a phase of playing with the COVERFLOW application i use the realnames of disk, path and folder. the original was C:\Program Files\Road Runner\Skins\RX8_Trans
              WHATS TO DO ?
              in my rr.ini is written:
              [Skins]
              skinpath=C:\Program Files\Road Runner\Skins\Freedom 2.1\
              transition=-1
              backgroundpath=C:\Program Files\Road Runner
              a skinpath you selected too, but did you wrote anything under backgroundpath ?
              if not, write it directly under [skins] see below.
              backgroundpath=C:\Program Files\Road Runner..... IF YOUR INSTALL IS DIFFERENT, TAKE YOUR INSTALLPATH.
              that means, for every skin the backgroundscreens are in folder BACKGROUNDS in path ROAD RUNNER.
              some guys fixed the backgroundscreens inside her skinpath. so you have in any skinpath a BACKGROUNDS folder... thanks for discspace killing.
              this is the way i copy the files inside the package, but forget to give a copy of the rr.ini.
              next step,
              in BACKGROUND.skin file please exchange the followed line
              /SD,00,00,180,180,"$backgroundpath$","*.jpg",,,,,,, ,
              SD,00,00,50,50,"$backgroundpath$\Backgrounds","*.j pg",0,,,,,,,
              that means, roadie looks under (whats written in variable $Backgroundpath$\folder Backgrounds.
              in your BACKGROUND.skin is written: SD,00,00,50,50,"$skinpath$Backgrounds","*.jpg",0,, ,,,,,.
                nice skin, i love it. Can't wait for the final version!
                  Thanks GF-ler,
                  your suggestions fixed the problem. The only other thing I have noticed is that IGuidance (4.0) doesn't start when I open the nav screen. I have it working in other skins... Otherwise, this is a fantasitic work of art!!!!
                  Nasa
                    Thanks GF-ler,
                    Nasa
                    i found the reason for the wrong installhelp file. you have the file of the simplistique skin.
                    whats about the coverflow application ? did you like it ? and how fast is your pc if it works. try it, before you convert all your musicpaths into needed COVERFLOW GENRE- format.
                    i make a new audio browser skin for NORMAL cover selection. with the coverflow MY pc stand still, nothing..njente..
                    with the IG4 i cant help, you know OLD-EUROPE should be no market for US factorys.
                    at the moment i complete the day version of this skin, think saturday i give the link.
                    regards
                      GF-ler,
                      I haven't played around with the coverflow app -- other than to see if it basically worked (ie: I haven't created the xml file yet). However, it does work and it does seem to be fairly smooth. That said, look at my system specs -- they are pretty hefty. Assuming it stays the same once I add the xml file, then yes -- I would say it is very cool. It may not figure into how I plan to organize my music, but that determination is a little down the road...
                      As far as IG4, I figured you OLD-EUROPE folks wouldn't know anything about IG. But I saw your initial post and thought I would ask.
                        GF-ler,
                        IG2.12 is the last europe version they build... and i work with it.
                        all other, on pc/laptop working navis are not so good.
                          Sexy Taiiimeeee
                            unfortunately the whole skin shows up blank when i load it up on my home or carpc. if i roll my mouse around, ill see buttons and borders slowly popup...
                              only for i installed the newest Road Runner..... and it runs.
                              in german we have a name for it.
                              thousands are sitting in the stadion, who gets the ball ???? YOU !!!
                              dont know whats your problem with the installation, but you have big one.
                              first the graphic of Simplistique didn't work, now the same graphic problems.
                              a simple call of a .png screen didn't work on your machine. there is no mystic code in the skins.
