closing an app before opening
  • closing an app before opening
    How can I execute the close command before the load command.
    What I need to do is close an open embedded app before I open another using one button push.
    Both apps have the same window name so that is the real problem here.
    New Age Garmin - Skin for RR
    CLOSE(APP)||LOAD
    use this tag for long command "||"
    If the name is same, try use WindowSpy (autoit tool) to get the window class.
    If you want to reopen the app use this CLOSE(APP)/KILL()||LOAD..... (the correct command spec in the skin command.txt)
    Englishlessness :(
      Here is the code I found and use now.
      This works real well..
      "CLOSEWINDOW;Form1||LOAD;games.SKIN;..."
      They all had the same window text so it made I had to do a little researching.
      I new about the || thing but just didnt know the correct command to use.
      THANKS FOR THE HELP
        You can use this "||" separator to use more command in one line
        this is an sample >
        "ESC||SETIND;!nR_SHORTER;ON||SETIND;!nR_FASTER;OFF ||RUNW;$SKINPATH$nRoute_scripts\nR_Preferences.exe | Button12 Check;;;"
        Englishlessness :(
          Yeah, I knew that, just didnt know what command to use to close the open app.
          THanks for the help
            "CLOSEWINDOW" - This allows you to close any running application based on the given window title. The application may
            request the user to save any unsaved data before closing, so beware.
            Example: "CLOSEWINDOW;Notepad"
            Englishlessness :(
              Yup and that is what I am using and it works great.
              Thanks...
