HD radio skin for LSX void 3 download
  • HD radio skin for LSX void 3 download
    With the permission of liquid_smoke....
    I modified the radio_ player.skin file to show examples of the Hd radio in action ...
    I'm using Directed DMHD-1000 Hd radio
    with the interface cable...
    Read the Readme file included
    Download link below :
    Looks cool.. I'm sure LS would be happy to include it for you..
    I would try to fit in a space to display what's on subchannels and a button to switch to them.
    Ride Runner RR's Myspace
      Actually the HD sub button you see on the pic is the switch button for HD1 and HD2
      back and forth ...
      And the Line under under the frequency shows info for current Subhannel in HD mode
      Took this from the command line found in the this thread
      http://www.mp3car.com/vbulletin/1136618-post2.html
        Hey hugenius79,
        if you send me your files, ill include them with the update. Just send them to the same email addy.
        beer replenishment fund
        mp3car live search
          available for download
            Hi.
            Mind if I ask how you integrated that tuner into the carputer?
            From what I can see it's an add on to an existing tuner.
            cheers
            Leonardo Da Vinci
              You just need to replace the current radio_player.skin with this one...and get the HD radio
              radio Directed DMHD-10000 ..
                Hmmm, How do you connect the interface cable to the carputer?
                I'm checking the product specs and it looks like you need an fm modulator or rca in jacks in order to get the sound into the 'puter/HU.
                It also apears the unit is just a "decoder". Maybe you're still using a head unit?
                Sorry for all the Q's, just trying to understand..............
                Cheers
                Leonardo Da Vinci
                  This is a tuner integrated with mitchjs' cable on one of the latest releases of RR. The cable costs about $25 on his site and the tuner you buy from wherever you want -- after that, it's free HD radio in the US + the usual analog radio as well.
                    Thanks for the info Guino!
                    (reaches for credit card...........)
                    Leonardo Da Vinci
                      HD radio in Roadrunner help
                      Hello,
                      I am hoping you guys may be able to help. I have downloaded hugenius79's skin that includes HD Radio and have also purchased the Directed dmhd-1000 and mitchjs cable. So far I got the HD radio to work under Mitchjs software but I can't seem to get it to run in Roadrunner.
                      Here is what I have done. I have done
                      -opened the HDRadio Folder and ran the runme1st.bat
                      -added hdradioport=10 to rr.ini
                      -added radiomode=8 to rr.ini
                      When I load the FM in LSX 3.0 I hear clicks from the HDRadio receiver but nothing else happens. Furthermore, I do not see the additions to the skin. I have both copied the radio_player.skin and hd-radio.gif to the LSX 3.0 skin Folder. Lastly, there are hidden buttons just above the close button and Freq+, I can't seem to find it. I got it once but didn't know how to change the settings to an FM station.
                      I am hoping someone can help
                      Regards
                        You need the .net 2 software installed as well.
                        Sounds like a similar problem sonic had:
                        http://www.mp3car.com/vbulletin/road...arpc-help.html
                        Guve the suggestions in that thread a try maybe?
                        Cheers
                        Leonardo Da Vinci
                          Well I have .net 2 installed in fact I did what sonic did and used unregme.cmd and reinstalled .net 2. If I am not mistaken I need to have .net 2 to run mitchjs hd player software. At this time I can use mitchjs hd player and it works fine. I just can't use it in Roadrunner
                          Are there any ideas why I can't get HD radio in Roadrunner?
                          Regards
                            Here's what i have in my RR.ini
                            hdradioport=1
                            radiomode=8
                            allowallfreqs=false
                            radioline=0
                            userbds=false
                            Make sure you have the latest Road Runner 11/02 the HD radio folder contents are diffrent than RR 09/29 Has a different HDradiocomm.dll file...
                            You will probably need to run runme1st.cmd again
                            Close HDRADIO PCR and before opening starting RR HD Radio ....
                            I had the same problem before that's how i solved it....
                            I never tried using port 10 though...
                              my first thing to tell you to do is change the port to one lower than 10.. low as possible in fact. Second thing is like the previous poster said check and make sure you are running the lastest RR release. Then check to make sure there's no hdradiocomm.dll present on your system other than the one if RR's HDRADIO folder. Open RR.ini and fix the port to the lower port you select in device manager, then run the unregme.cmd then run the runme1st.cmd . With a little luck yours will pop on just like mine did.
                              Live mp3Car Facebook Chat
