GPS Indicator not working
  • GPS Indicator not working
    I try to put an GPS indicator on my skin, but I can't get it to work.
    This is what I've put in my skin-file:
    Code:
    /, Y, Back Slider file path
    Y01,"gpsslider\slider_*.gif"
    /,   x   y   w   h   x1  y1  w1  h1  O Style Pointer file path h2  Code  tooltip
    S01,671,007,028,022,661,007,028,022,H,01,"gpsslider\pointer.gif",01,GPSSIGNAL,""
    Within the skin folder I have created the folder gpsslider. It contains an completely transparent pointer.gif and 20 slider files (slider_0.gif to slider_20.gif).
    -slider_0 to slider_2 indicate a bad signal
    -slider_3 and slider_4 indicate medium signal
    -slider_5 to slider_20 indicate a good signal
    The GPS signal in RR is working, I've lock to 5-6 satellites, still my skin shows the symbol for a bad signal.
    Code:
    first question, is the box you want to show 28x22 pixel.
    why you want a pointer, who should be 1 pix high, when you split the signal into 20 screens ?
    S01,671,007,28,22,661,007,28,22,H,01,"",28,"GPSSIG NAL",
    thats enough.
      Its not really a slider, but just a sattelite symbol in red, yellow and green. The pointer isn't required, but I guess you need to supply one for sliders, don't you ?
        no you need no one.
        dont forget the "Anführungszeichen" in front and behind GPSSIGNAL and all will work.
          Well, duh ! How could I miss this ^^ ? Ok, I'll try, thank you .
