Having a bit of trouble getting transparent iLists to work...
  • Having a bit of trouble getting transparent iLists to work...
    So here's my problem. The dirlist & playlist iList won't show up:
    ...with the following code in my skin:
    Code:
    IL,PL,unsel.png,sel.png,,1,20,70
    IL,DL,unsel.png,sel.png,,1,20,70
    SD,0,03
    What am I doing wrong?
    TIA!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    I'm pretty sure you can only have one iList per screen at a time.
    Did you set up the directory lists correctly?
    Code:
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    Try it with just one and then the other list and see if it works.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
      Both iLists show if I use bmp's for the images.
      And both lists are setup properly.
        it's possible to have 2 ilist... it works in mine!
        Sal R. if you nedd it I can email you my code...
        Live today like it is your last day, and behave as though you will live forever...
        my WEBSITE
        MapMonkey Dalai skin-preview-download ITA-email me for ENG
        Road Runner CrystalBlue skin-preview-beta release
          here it is how it looks like...
          my WEBSITE
            Ygpm.
              I think you need a transparent.png in your skin folder, it doesn't look like you've referenced it in your IL code, so maybe try and create a simple transparent.png (it won't show, it just needs to exist, or rename unsel.png as transparent.png) and reference it in the IL:
              Code:
              IL,pl,transparent.png,sel.png,,1,20,70
              Car PC Progress:
              View my
              Worklog
              Road Runner Skins
              Website
                I have two ilist in both of my current skins, new age and concept
                I do not have a PNG for transparency either.
                Here is the code I use..
                Code:
                IL,DL,RGBFF00FF,RGBFF00FF,******End of List******,2,20,50
                IL,PL,RGBFF00FF,RGBFF00FF,******End of List******,2,20,50
                Works great
                New Age Garmin - Skin for RR
