Skin Wont Change
  • Skin Wont Change
    Hi,
    I looked about but can not find an answer to the following, easy for you guys I know.
    Why when I use the skin editor and change a menu in the BMV2 save it etc, then when I open road runner the menu hasnt changed?
    I checked the location of skin to open and edit and the skin RR is using and both one and the same.
    are you changing the actual images or the skin elements (commands/labels/etc.). Describe what ur attempting to change and it'll help to provide a solution.
    Live mp3Car Facebook Chat
      I know from experience that if you don't go File, Save, it doesn't save automatically on exit.
        Hi,
        what I was doing was changing the RDS station name in the radio skin. I moved it and made it larger and clicked file, save and got the message, skin saved etc.
          i remeber from past editors if its not saving to your skin file ,have alook in the skineditor folder for a temp skin file that will be the 1 you just saved.
          check your save path in the settings/editor settings tab in editor
          mine says
          C:\Program Files\Road Runner\Skins
          Riderunner / Genesis
          Wifiman_NET:Version 1.0.0
            Hi Again!
            Just checked, yep mine says:
            C:\Program Files\Road Runner\Skins.
            Also copied the settings txt:
            ObjectColor=16777215
            ObjectBorder=2
            SelectedObjectColor=65535
            SelectedObjectBorder=4
            EnableMouseOver=True
            EnableMouseDown=True
            EnableFlashPlayback=True
            ENABLEAUTOUPDATE=True
            RRSkinPath=C:\Program Files\Road Runner\Skins
            EnableSaveConformation=True
            PropertyBoxWidth=6065
            LWO_1=
            LWO_2=
            LWO_3=
              Any ideas?
                To actually make the label larger you need to define a font size. Simply dragging the label box larger in skin editor will not make the label any bigger.
                I think that is your issue/
                  HI<
                  I did change the font size, the size of the label, moved the lable, clicked save skin, message "saved skin" appears but when I shutdown and restart rr, nothing has changed no matter what I do to the skin.
                    Originally posted by the_big_1 View Post
                    HI<
                    If all else fails...there's always notepad...
                    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                      I wounder if its an Vista problem as I seem to have many little issues with editors and plugins on my Vista pc and a lot less on my XP pc.
                        Probably, Vista baaaaaad
                          well that answers that q? then VISTA route of all evil
                            maybe your skin files somehow inherited a read only permission. That would explain why editing them doesn't do anything.
                            And as Sal stated, you can always open the .skin file in notepad and manually edit it.
