Help - ExecTBL
  • Help - ExecTBL
    Hi guys,
    Trying to get Sygic Drive running in Night_Apple Skin and it uses a ExecTBL file.
    If I use the following it works but soon as I add switches it does not.
    ORDER UNDER MENU-BUTTONS
    /path .GPS.............................................. ...........{ path to your gps application }{ window title}
    "Sygic","LOAD;Sygic_FullScreen.skin;RUN;C:\drive_x p\drive.exe"
    This works, but this does not....
    "Sygic","LOAD;Sygic_FullScreen.skin;RUN;C:\drive_x p\drive.exe -r800x480 -no-safety,1
    It does not work.
    How do I get switches to work in a ExecTBL.
    Cheers
    Try using "|" instead of "-"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      Originally posted by Firebird2 View Post
      Hi guys,
      Cheers
      You left off a quote at the end of the command
      New Age Garmin - Skin for RR
        You may not be able to have command line arguments in a button command. Create a batch file like drive.bat
        put this in it.
        Originally posted by DRIVE.BAT View Post
        C:\drive_xp\drive.exe -r800x480 -no-safety,1
        Then put this in your extbl.ini
        Originally posted by EXTBL.INI View Post
        "Sygic","LOAD;Sygic_FullScreen.skin;C:\drive_x p\drive.bat"
          if you are trying to embed an app use this example from the skincommands.txt
          LOAD;EXTERNAL_GPS.SKIN;Destinator GPS;Destinator3.EXE;Destinator
          Command;Skin file;Window Name;Command Line Command;Voiced Text
