DFX Button Editor Problems Discussion
  • DFX Button Editor Problems Discussion
    This is a thread to discuss and hopefully get the button editor working for all.
    First make sure that you are using the latest one, which has a window title of:
    "3.0/4.0 DFX Menu Button Editor by BlueZX3"
    #1 List which version of the skin 3.0 or 4.0.
    #2 Now describe what its either doing or not doing and when its doing it with any descriptions of any error messages.
    And possibly attach your "Exectbl.ini" file in your DFX folder to your post, do NOT copy/paste the file to your post please.
    We will get to the bottom of this!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    I've noticed that when I change more than one button property at a time, it does not save correctly. Example: I click an unused button to edit, change the name to "Gas Prices" the command to "rrgas" and label to "Gas Prices", and click OK. It shows up with the new button name in the editor. I click "Save and Exit", and when I relaunch the button editor, the button shows up as "UnUsed" as if nothing was saved.
    However, if I change one button property at a time and "save and exit" between each change, it all works fine, for me at least. This is for DFX 4.0.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
      Will check and comfirm my results.
      DFX 5.1.1 Skin
      Appstore Link
      RRMedia
      RRExtended
      DFXVoice
        How do you go about changing the button anyway? I dont see a dfxbutton editor.
        I just want to add my own pictures next to the buttons instead of what is there already.
          When you press and hold a button, and have the choices, simply use the name you see on those buttons "GPS Gas" for instance. Just put a png named "GPS Gas.png" into the MenuIcons folder. It will then immediately show up as the icon on the main menu.
          My Fiero Build Thread
            Sweet got it.
            WTf, I just opened it and and I get a pic of your car with eyes like the guy from cars. I've had it set to the mitsu symbol forever and it just changes on it's own now. It won't change back.
              Well, both doing and checking the code, I can not create this issue. By chance, after you change all three properties and save, have you looked in the exectbl file and see if any part of newly created button is getting saved?
              DFX 5.1.1 Skin
              Appstore Link
              RRMedia
              RRExtended
              DFXVoice
                OK, heres a thing.
                I found that when using the editor to create/edit a button for the Garmin Overlay specifically, i put the code in, apply it, save the changes.
                Then I go into the config files and the button script hasn't been updated ? I had to manually update the button def, and then it worked a treat.
                If it's my system being daft, so be it, wouldn't surprise me
                Just thought I'd let ya know.
