Save RDSName like FMPRESET ??
  • Save RDSName like FMPRESET ??
    need your help,
    in my radio-skin i have 9 buttons with preset function for FREQUENCY.
    in the same button (in lower position) i want to save the RDSName which is under the Frequence.
    had a look in other skins if anyone does it, but find no example how to copy a ROADRUNNER value (RDSNAME) into a variable ($STAT1....9$).
    thanks for help
    how about something like this ...
    "FMPRESET;PRESET1||SETVARBYCODE;FMP01;FREQUENCE||S AVETOSKIN;FMP01;$FMP01$||SETVARBYCODE;RDS01;RDSNAM E||SAVETOSKIN;RDS01;$RDS01$"
    This will save save the frequency, and the RDSNAME to two skin variables as well as setting the radio preset.
    In your skin then you use the variables $FMP01$ and $RDS01$ for frequency and RDSname saved for that preset ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
      yeah it works, thanks a lot.
      the handling with variables is a problem for me.
      somethings needs longer, but i dont give up.
      edit:
      there is another problem with the save of the RDSName.
      at the moment i push a button for changing the frequence, there is no RDSName.
      what it do is read the label from the station before or read nothing.
      a function like.....
      short push..change the frequence...no changing of RDS-variable
      longer push...change the frequence and read the RDSName into the RDS-variable.
