Windows sendkey methods, proved helpful.
  • Windows sendkey methods, proved helpful.
    I've been following this forum for a little over a year now and I think this will help when peeps are trying to use other applications embedded inside of Road Runner skins. It's a pretty good breakdown of using windows send key commands. http://msdn.microsoft.com/en-us/libr...83(VS.85).aspx
    Note: Don't forget to use the "activate" command proceeding each sendkey. So the command will get sent to the right app.
    This was a big help when I was integrating KMplayer into my roadrunner install. It turned out very well.
    ATTENTION FELLOW CAR PC ENTHUSIASTS, POWER ACOUSTIC = CAR PC KRYPTONITE!!!! AVOID AT ALL COSTS!!!!
    To my adoring fans, No my Toyota's gas pedal didn't get stuck! Instead I saw you crossing the street and decided to floor it! Unfortunately, I MISSED!!!
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      basic road runner kmplayer controls
      I whipped this up using some basic shapes and some sendkeys, and KMplayer set in default skin w\shade mode. It runs Kmplayer perfectly. I can play, navigate, and resume from last position on store bought dvd's pretty flawlessly. And also navigate dvd special features and chapters in a breeze. Nice thing is KMplayer is FREE, loaded with features, and has no nag-ware whatsoever . I prefer it way over power dvd or win dvd.
      Bad thing is i can't draw. I never have or will be able to, so no flashy frosted buttons here.
        Um...This is no different than using the "SendKey" cmd in RR.
        Straight from the "Skin Commands.txt" file
        "SENDKEY" - This lets you send keys to any application -- This is in VB's sendkeys method format.
        Examples: "SENDKEY;{PGDOWN}", "SENDKEY;%A", "SENDKEY;{LEFT}"
        If you need more details on this, look at VB's documentation or drop me a line.
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          So far it's been pretty self explanatory. I'll let you know if I run into any roadblocks.
            Now that I had a quick re-glance at this thread....you were merely trying to help/show the the unknowing/misinformed how to use that RR cmd. Correct?
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              Yes that is correct! With example
                Yeah, it just take the gessing out of it with the commands already spelled-out. Interesting the bit about "print-screen".
                OLD SYSTEM (DEAD)
                M2-ATX Power Supply
                Windows XP SP3
                  toyotatyrant:
                  how did you keep KMPlayer from minimizing like Winamp?
                    Originally posted by blackcar View Post
                    toyotatyrant:
                    Check out my post here. This should help with kmplayer and winamp conflicting with each other. http://www.mp3car.com/vbulletin/road...coverjuke.html
