Need SWISH FLASH help
  • Need SWISH FLASH help
    for my new skins i need a plug....if flash or autoit..its not important.
    because i cant find a point of start i ask here for help.
    while roadrunner only works with .gif pics in his STATUS showing, and .gif is too bad for my symbol pics i will do it in flash and .png file format.
    what i want to do.
    in the folder $skinpath$ i make a folder named STATUS. in this folder are saved the different screens for PLAY-OFF-, PLAY-ON-, PAUSE-OFF-, PAUSE-ON-, STOP-OFF-, STOP-ON-.
    the screens, ended -ON- are showing if the cursor is -OVER- the button PLAY/PAUSE/STOP.
    a down version i didnt need, because the time to see the new symbol is to short.
    if theres no cursor over the button it should show the symbol "STATUS" say.
    therefore are the pics PLAY-OFF-, PAUSE-OFF- and STOP-OFF-.
    for better understanding ive make a floating diagram
    Click image for larger version
Name:	flash button.jpg
    hope that one of the flash coder can give me a kick.
    Are you wanting something like my Radio Flash object... I build a flash file that allows you to click and go to different skins. and it changes depending on the inputs it receives. Is that wanting your wanting?
    Let me know...
    Troy
    Batmaninls
    www.evorbust.com
      Let me know...
      Troy
      where can i find the source of it, perhaps i find a point of start.
        so you want indicators which are .pngs? is that what your after?
        2005 Nissan Xtrail
        DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
        worklog
          yeah, its coded under the "I"...indicator command.
          with the variable "STATUS" of roadrunner you can show a text like PLAY/PAUSE/STOP (under "L") or a graphic symbol you named as PLAY/PAUSE/STOP (under "I").
          BUT it only shows .gif files. the buttons i made are too colorfull for the .gif format (it only works with 256colors). therefore, that i can use the .png format for the graphicsymbols i will show, i want to use flash or autoit.
          another unlucky thing from the indicator command is, it only shows one pic from the signal you ask. if your cursor is over or pressed it didnt show you the second or third symbol, like you use the _off/_on/_down screen selection in your .skin file.
          some skins, me too in the simplistique skin, are using a font symbol for showing the status. thats for this skin i make not possible. its a style break in its own.
            2005 Nissan Xtrail
            worklog
              another flash problem,
              i want to make the iDrive skin handle like BMW it makes. a wheel for turning and selecting functions i want to start.
              now i have the problem that the background of the DirectoryList box is transparent and it shows me the selected backgroundcolor.
              i never understand (perhaps its my bad english or the notes are written) the working of screens with fields in pink color.
              is only the part of the screen, i make in pink, transparent ?
              and must i write any commands inside the skin file. an example would be nice.
              another question to the swish user.
              i make a button with UP / OVER / DOWN function, if i load a image in part of OVER or DOWN it will be in another size as it draws. it told me to be 100%, but its most smaller. it nervs to bring it in size i want. if the OVER part is ready and i make a group of it. i go to DOWN and thougt i can copy the group and it will be in same size as in OVER. NONE, i must edit it again.
              is there any switch inside SWISH for fix the copy of images ?
              the resize of images is only if i work inside buttons, any other insert is in size like the original drawed.
