OSKTOCMD problem - solved
  • OSKTOCMD problem - solved
    I have the following command for a button in my skin:
    Code:
    "OSKTOCMD;CJ_LETTER;SKIPTOLETTER"
    and in my execTBL:
    Code:
    "SKIPTOLETTER","RUN;$pluginspath$CJSend.exe|{$CJ_LETTER$}"
    For some reason, SKIPTOLETTER is not being executed when I click Enter in the OSK.
    Even more strange, If I use the RR SKin Tool to pass the button command, it will work, and SKIPTOLETTER is executed.
    Any ideas? Any others with this issue?
    Edit:
    Adding "||" to the beginning of the command, makes it work correctly.
    Code:
    and in my execTBL:
    Code:
    "SKIPTOLETTER";"RUN;$pluginspath$CJSend.exe|{$CJ_LETTER$}"
    Typo.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      Originally posted by Sal R. View Post
      Typo.
      Typo is with the post, my bad. I have it correct in ExecTBL and it still does not work.
      -I have determined that using the button command will not save the value to CJ_LETTER, when I call the exact same command in RR Skin Tool, it will save the value to CJ_LETTER and execute SKIPTOLETTER. I can not figure out why this is?
        Here is relevant information from debug log. The first time, OSKTOCMD is run is using the button in skin. The second is using RR Skin Tool:
        Code:
        2/26/2009 6:05:28 PM: Enter Exec: False, coverjuke.skin, "ONBTNPRESS||GOTOALBUM", False
        2/26/2009 6:05:28 PM: Que Exec: True, coverjuke.skin, "ONBTNPRESS||GOTOALBUM", False
        2/26/2009 6:05:28 PM: Executing: ONBTNPRESS
        2/26/2009 6:05:28 PM: Que Exec: True, coverjuke.skin, "GOTOALBUM", False
        2/26/2009 6:05:28 PM: Executing: OSKTOCMD;CJ_LETTER;SKIPTOLETTER
        2/26/2009 6:05:29 PM: Que Exec: True, osk.skin, "ONSCREENCHANGE", False
        2/26/2009 6:05:29 PM: Executing: ONSCREENCHANGE
        2/26/2009 6:05:29 PM: Leave Exec: False, osk.skin, ONSCREENCHANGE, False
        2/26/2009 6:05:33 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||r", False
        2/26/2009 6:05:33 PM: Que Exec: True, osk.skin, "ONBTNPRESS||r", False
        2/26/2009 6:05:33 PM: Executing: ONBTNPRESS
        2/26/2009 6:05:33 PM: Que Exec: True, osk.skin, "r", False
        2/26/2009 6:05:33 PM: Executing: r
        2/26/2009 6:05:33 PM: Command not executed: r
        2/26/2009 6:05:33 PM: Que Exec: True, osk.skin, "ONCOMMANDINVALID", False
        2/26/2009 6:05:34 PM: Executing: ONCOMMANDINVALID
        2/26/2009 6:05:34 PM: Leave Exec: False, osk.skin, ONCOMMANDINVALID, False
        2/26/2009 6:05:35 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||ENTER", False
        2/26/2009 6:05:35 PM: Que Exec: True, osk.skin, "ONBTNPRESS||ENTER", False
        2/26/2009 6:05:35 PM: Executing: ONBTNPRESS
        2/26/2009 6:05:35 PM: Que Exec: True, osk.skin, "ENTER", False
        2/26/2009 6:05:36 PM: Executing: ENTER
        2/26/2009 6:05:36 PM: CheckResume: ResumeMusic=2 WasRadio=0
        2/26/2009 6:05:36 PM: Enter Exec: True, coverjuke.skin, , False
        2/26/2009 6:05:36 PM: Que Exec: True, coverjuke.skin, "ONSCREENCHANGE", False
        2/26/2009 6:05:36 PM: Executing: ONSCREENCHANGE
        2/26/2009 6:05:36 PM: Leave Exec: False, coverjuke.skin, ONSCREENCHANGE, False
        2/26/2009 6:05:56 PM: Enter Exec: False, coverjuke.skin, , False
        2/26/2009 6:05:57 PM: Que Exec: True, coverjuke.skin, "OSKTOCMD;CJ_LETTER;SKIPTOLETTER", False
        2/26/2009 6:05:57 PM: Executing: OSKTOCMD;CJ_LETTER;SKIPTOLETTER
        2/26/2009 6:05:57 PM: Enter Exec: True, osk.skin, , False
        2/26/2009 6:05:57 PM: Que Exec: True, osk.skin, "ONSCREENCHANGE", False
        2/26/2009 6:05:57 PM: Executing: ONSCREENCHANGE
        2/26/2009 6:05:57 PM: Leave Exec: False, osk.skin, ONSCREENCHANGE, False
        2/26/2009 6:05:58 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||r", False
        2/26/2009 6:05:58 PM: Que Exec: True, osk.skin, "ONBTNPRESS||r", False
        2/26/2009 6:05:58 PM: Executing: ONBTNPRESS
        2/26/2009 6:05:58 PM: Que Exec: True, osk.skin, "r", False
        2/26/2009 6:05:58 PM: Executing: r
        2/26/2009 6:05:58 PM: Command not executed: r
        2/26/2009 6:05:58 PM: Que Exec: True, osk.skin, "ONCOMMANDINVALID", False
        2/26/2009 6:05:58 PM: Executing: ONCOMMANDINVALID
        2/26/2009 6:05:58 PM: Leave Exec: False, osk.skin, ONCOMMANDINVALID, False
        2/26/2009 6:06:00 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||ENTER", False
        2/26/2009 6:06:00 PM: Que Exec: True, osk.skin, "ONBTNPRESS||ENTER", False
        2/26/2009 6:06:00 PM: Executing: ONBTNPRESS
        2/26/2009 6:06:00 PM: Que Exec: True, osk.skin, "ENTER", False
        2/26/2009 6:06:00 PM: Executing: ENTER
        2/26/2009 6:06:00 PM: CheckResume: ResumeMusic=2 WasRadio=0
        2/26/2009 6:06:00 PM: Enter Exec: True, coverjuke.skin, , False
        2/26/2009 6:06:01 PM: Que Exec: True, coverjuke.skin, "ONSCREENCHANGE", False
        2/26/2009 6:06:01 PM: Executing: ONSCREENCHANGE
        2/26/2009 6:06:01 PM: Que Exec: True, coverjuke.skin, "SKIPTOLETTER", False
        2/26/2009 6:06:01 PM: Executing: RUNQ;C:\Program Files\RideRunner\Plugins\CJSend.exe|{r}
        2/26/2009 6:06:01 PM: Shell: "C:\Program Files\RideRunner\Plugins\CJSend.exe" {r}
        2/26/2009 6:06:01 PM: Leave Exec: False, coverjuke.skin, RUNQ;C:\Program Files\RideRunner\Plugins\CJSend.exe|{r}, False
        As you can see, the first time the command is used, the SKIPTOLETTER is not executed. The second time using RR Skin Tool, it is executed.
          Any chance "SKIPTOLETTER" is defined in another part of ExecTBL?
            no, my execTBL is pretty basic unlike others cough:MITCH:cough; I might reinstall RR tonight and see if that fixes the issue. Has anyone tried this, and had the same problem?
              You probably mean CHUCK!
              OLD SYSTEM (DEAD)
              Intel D945GCLF2 Dual Core ATOM
              Lilliput 7" 629GL 2008 LED Backlight
              BU-353 USB GPS Receiver / iGuidance / IGO8
              M2-ATX Power Supply
              RideRunner Front End / Various Skins
              Windows XP SP3
                Yeh, Chuck... Either way im sure Mitch's is ridiculous too.
                  try it like this, (include the double pipes)
                  Code:
                  "||OSKTOCMD;CJ_LETTER;JUMPTOLETTER"
                  if you want to send letter "R" coverjuke is getting "{R}" the way you have it, and you need to send "R" only
                  no"{}"
                  Code:
                  "JUMPTOLETTER","RUN;$pluginspath$CJSend.exe|$CJ_LETTER$"
                  also, is always a good idea to run scripts from the source when testing.
                  QUESTION:
                  why you need a script to send a KEY to coverjuke, you can do that with pure RR code.
                  BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                  RRTube ==> [View/Download Youtube Videos]
                  WifiMan ==> [Wifi Manager]
                  RRec ==> [Audio Capture]
                  If You Want To Be Given Everything, Give Everything Up ...
                  Bird York -- In The Deep --
                    That worked for me. Coverflow is complete for me. i couldn't ask for anything more
                    506 Skin
                    506 Flash!
                    NEVER BLEND IN!!!
                      The way coverjuke is embedded, you cannot send a direct keystroke to it. So using RR's sendkey will do nothing but stare back at you. So I wrote CJSend to send the keys directly to coverjuke when it has been embedded.
                      Secondly, I was unable to send just R to coverjuke and have it understand. I will retry the issue, but using AutoIT, I had to send the commands with {} for coverjuke to perform the operation. I will look back into it, but this was my reasoning. I will also try the double pipes. The source code for CJSend is in the download, if you wanted to have a look at it.
                        Here is the real question, why would RR Skin Tool be able to perform the command correctly, but using the command in a button on the skin will not execute the command?
                        Edit:
                        Adding "||" to the beginning fixes the issue. Thank you El Camino
                          "{$GOTOALBUM","||OSKTOCMD;CJ_LETTER;RUN;$skinpathh $CJSend.exe {$CJ_LETTER
                          not worrking for me....
                            The above command is a little off:
                            it should look like:
                            Code:
                            "GOTOALBUM","||OSKTOCMD;CJ_LETTER;RUN;$skinpath$CJSend.exe|{$CJ_LETTER$}"
                            or you can make the Run command its own command, such as:
                            Code:
                            "GOTOALBUM","||OSKTOCMD;CJ_LETTER;SKIPTOLETTER"
                            "SKIPTOLETTER","RUN;$skinpath$CJSend.exe|{$CJ_LETTER$}"
                            These commands should be placed in your execTBL.ini
                              so i need to put two commands on one button (GOTOALBUM+SKIPTOLETTER)?
