iGuidance not working properly with Ride Runner
  • iGuidance not working properly with Ride Runner
    iGuidance won't work for me with the new Ride Runner and Carwings skin. It looks like the iGuidance isn't opening properly inside of RR and a portion of the skin covers the "Menu" button so I can't change the destination.
    Check your window name in rr config.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      that was the first thing i checked and it says iGuidance....i also get a window that opens called "Float" but i can't see what's in it......
        Sounds like the overlay is not working right. Post a screenshot.
        OLD SYSTEM (DEAD)
        M2-ATX Power Supply
        Windows XP SP3
          I'm having the same trouble. I'm new to RR so I hope one of the experts on here has some ideas.
          Mind Scream
          Here is a screenshot:
          Mind Scream out
            Nothing wrong with it, that's how it is in carwings. The "navi" button will let you enter a destination.
            OLD SYSTEM (DEAD)
            M2-ATX Power Supply
            Windows XP SP3
              Sure it will, as long as you don't need any letters under the menu. That's where the biggest problem comes from.
              A H P and V are unusable.
              Mind Scream out
                I see. Never noticed cause i don't use UMPC. Go to the carwings thread to learn how to disable the overlay.
                OLD SYSTEM (DEAD)
                M2-ATX Power Supply
                Windows XP SP3
                  Mind Scream
                  Woah, I don't get any of those options on the left. I wouldn't mind so much if I did. How did you get those to come up?
                  I'll post a screen shot sometime tomorrow. I'm in the middle of a cross-country roadtrip and only really mess with the carputer while sitting at a rest stop taking a break from driving....
                    Guess I'm just lucky like that
                    I'll check out the carwings threads and see what I can find
                    Mind Scream out
                      Easy, in menu.skin check for the GPS||open"iwing.exe" or something similar and remove everything except GPS....and in external_gps.skin change EXIT||CloseWindow to just EXIT...if you need more help PM me
                        I've never had any keyboard problem using iG with the float overlay.
                        AutoPC v1 (Retired) - AutoPC v2 (in progress) - www.shocknet.us
                          Not keyboard Blk, OSK! When you call the OSK, some letters fall under a portion of the overlay making them (the letters) unusable. Happens with IG UMPC.
                          OLD SYSTEM (DEAD)
                          M2-ATX Power Supply
                          Windows XP SP3
                            I meant the OSK when I mentioned 'keyboard'
                            Yes the letters fall under the menu in the UMPC but their rightmost edge remain clickable. I just tried it and took a screen cap. I would be nice if the UMPC data entry menu was area definable for position.
                            The normal iG OSK does not fall under any of the menu.
                              I was wondering that about the iGuidance skin as well but I have an easier solution.....switch to eLite Lite.
                              Ampie Case
                              256 MB DDR2 PC5400
                              Xenarc 700TSV - VGA Monitor
                              Intel D945GCLF Motherboard
                              M2-ATX-HV
                              2005 Honda Civic
