Load skin on indicator change
  • Load skin on indicator change
    Anyone know how to have a skin popup when and indicator changes?
    I tried putting this in my exectbl.ini of my skin but this is not working.
    "BYIND;MOBILEPHONE_INCOMMINGCALL;LOAD;MOBILEPHONE. SKIN<<"
    The indicator is "MOBILEPHONE_INCOMMINGCALL"
    and I want it to run "LOAD;MOBILEPHONE.SKIN" when the indicator is true and do nothing when it is false.
    My Work Thread:
    http://www.mp3car.com/vbulletin/showthread.php?t=72552
    Source switcher for Lill
    http://www.mp3car.com/vbulletin/show...d=1#post841007
    What your asking is in my RRExtended plugin, an indicator checker/poller. It will execute a cmd when the specified ind changes state and then you would just add that whole line to the fired event by my plugin.
    See this post HERE
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      eric the mobilephone plugin is supposed to do this automatically. When an incoming call is coming its supposed to open mobile_call.skin.
      Live mp3Car Facebook Chat
        See this post HERE
        Thank you.
        I am trying to get this to work. First I tried my implementation but I was unable to get it to work so I then tried your exact example and that doesnt work either. Any advice?
        1) I placed the RRExtended folder into Road Runner folder.
        2) I ran the _Install.cmd to register the dll.
        3) I placed "IndPoller_Enabled=True" into my rr.ini (w/o quotes) and also into my skin.ini (only because it wasn't working)
        4) I placed "||IndPoller_Add;MUTE;2;Mute _Ind_Changed" on the end of my ONSKINSTART line (inside the quotes) in my exectbl.ini for my skin.
        5) I placed the line "Mute_Ind_Changed","Audio||WAIT;2||Load;Audio_brow ser.skin" in my exectbl.ini for my skin.
        6) save everything and launch RR. Test by clicking the mute button and wait, nothing happens.
        My Work Thread:
          Really? hmmm. It isn't working for me. For that matter I can't get mobilephoneBMV2.skin to load either. If I place a command to open that skin on a button some where the visual portion of the app goes away when I click the button. Maybe that is related. I'll dig around and try and figure this out.
          My Work Thread:
            @SonicXtacy02 there is no mobile_call.skin in the files I downloaded for the mobile call plugin. Where did you get this skin from?
            My Work Thread:
              You have to make it, I'm guessing that there were now sample skin/screens included with the plugin.
              DFX 5.1.1 Skin
              Appstore Link
              RRMedia
              RRExtended
              DFXVoice
                from post 1 of the mobilephone plugin
                When ringing occures the dll now tells RR to load the mobilecall.skin regardless of current skin screen.
                that being said.. it doesnt work for me either.. post the problem in that thread so he can get it working
                  OK, I got action on mute to work so I have the indicator change thingy working now. Thanks for your help.
                  My Work Thread:
                    O.K. So what does the working code look like?
                      It was exactly like the code he used in the post referenced in post #2 of this thread. Getting the dll registered was the key.
                      However, I am now trying to get the ind_poller working on the carcomputer (I used a test machine before) and am unable to do it. Still working on it.
                      My Work Thread:
                        I figured it out. Both times I started with the RRExtended dir inside the road runner folder. Even when the Dll is registered it will NOT work from there. Put the RRExtended folder inside the plugins folder and register the dll and it will work. /Whew.
                        My Work Thread:
