Problem instal add sof games
  • Problem instal add sof games
    I took the program to run flash move out of FreeICE 1.92, and tried to install in the first Ride Runer, times and then stopped running!
    Running program this:
    B,321,328,58,90,"LOAD;game_flash_all.SKIN;gameload er;RUN;C:\RideRunner\Skins\audi\Games\FreeICE\skin s\defaultgames.exe;gameloader"
    only
    B,707,352,58,90,"LOAD;game_flash_all.SKIN;gameload er;$RRPATH$Skins\audi\Games\FreeICE\skins\default\ games.exe;gameloader"
    The program is run, and if run under the Ride Runner, as soon die!
    RUSSIA - WINER!!!
    Up!
    RUSSIA - WINER!!!
      the game Loader in your files is for freeice only,
      find attached another to do it for you, it use's Blue's RRextended .
      the skin files are reference only will need to change to work in your skin the 3rd line (graphics)
      and you may want to change the paths in the Games.skin .
      to add more games open the games.txt and just add the titles of the games .
      this must be the same title as the flash game.
      ENJOY
      Riderunner / Genesis
      Wifiman_NET:Version 1.0.0
        ENJOY
        Please send me :
        and instal information
        Iam instal:
        1. Copy folder "Flash" to folder Skins, or Skins\My_skin?
        2. add information exectbl.ini
        3. copy game.skin and games.skin my folder skin (skins\my_skin)
        4. Create button "games" in main.skin
        no work!!!
        RUSSIA - WINER!!!
          just change that to 1 of your own graphics in your skin. i'm sure you must have a popup in your skin somewhere or just use a full skin. Images\slider1.png is just the way i call different graphics into the skin , won't stop it working.
          in Games.skin you may need to change "in RED"
          SETVARBYCODE;GAME;LISTTEXT||EXIT||RRFileCopy;$SKIN PATH$Flash\$GAME$.swf;$SKINPATH$Flash\Game.swf||LOAD;Game.ski n"
          this is where the games are held , change it to what ever you have called the games folder, must be in skin file
          to really spoon feed:
          Games Folder = Skin folder
          add line to Exectbl.ini
          skin files = skin folder
          change 3rd line in skin files, to match your graphics
          change path to games folder in Games.skin as shown above.
            updated files should work straight off just drop them into your skin, add GAMES to your menu button or where ever
            add line from exectbl.ini
            useing carwings files
              no work!!
              please edit my skin!
              screen to button!!
              RUSSIA - WINER!!!
                Nice Clock you've got there...Where can I get it.
                  offtope!!!
                  RUSSIA - WINER!!!
                    LOL.. now who was it , that i asked to use the clock ,mmmmm my memory is not as good be
                    @pafftis it works in your skin just tryed, the only thing i did was in Exectbl.ini "GAMES" line changed Menu = LOAD
                    all good works fine
                      here you go all works fine here, i have changed the graphics to your skin files
                      lets see what happens
                        It does not work, download your edited file, choose the game but started one game and tazhe!
                        RUSSIA - WINER!!!
                          do you get the menu of the games appear ????
                          do have RRextended.dll installed?????
                          not all games are in the list edit Games.txt titles in games.txt must match flash game title without .swf
                            yas!
                            yas!
                            yas!
                            RUSSIA - WINER!!!
                              strange works perfect here, the only thing i can think of is that rrexented is not installed correctly, post rr.ini, you could try rrexteneded debug too, it way show somthing,
