Carwings on RideRunner ??
  • Carwings on RideRunner ??
    It is saying that my Carwings_Dynamic folder does not contain a valid skin.....What does this mean??
    Again, U people need to give more info in order to get info...
    Did you :
    use the installer?
    Run the config and set all your paths?
    Check your ..\skins\ folder to make sure that the folder is there ("Carwings_Dynamic")?
    Check that you have both a General.ini and Menu.skin in that folder?
    Which RR version are you trying to use?
    Just some things to try look for first.
    PS. In future, if posting about a bug/issue also list important info that help others to help you. Most will just pass on by if they see that the poster has NOT listed any or enough info to help solve the problem.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      The skin folder is within another folder - been there done that!
      OLD SYSTEM (DEAD)
      Intel D945GCLF2 Dual Core ATOM
      Lilliput 7" 629GL 2008 LED Backlight
      BU-353 USB GPS Receiver / iGuidance / IGO8
      M2-ATX Power Supply
      RideRunner Front End / Various Skins
      Windows XP SP3
