BMV2 Mixer For Foobar2000 w/ 18-Band EQ
  • BMV2 Mixer For Foobar2000 w/ 18-Band EQ
    I use the tried and true BMV2 skin and decided to start using Foobar2000 to play my FLAC files. Foobar has a great 18-Band equalizer as most of you probably know, and I wanted to be able to access it properly within RideRunner so I through together a simple mixer skin featuring the 18-band EQ. Obviously 18 sliders take up more space than previous so to do it w/o losing other slider features I had to take out the presets (I never used them anyway). Seems to work ok for me, but if anyone come across any problems let me know.
    Génial !!!!
    I shall try to do it for Carwings
      Originally posted by pierrotm777 View Post
      Génial !!!!
      Its pretty basic. All the coding is the same just add in frequencies 11-18 and remove the preamp.
      I was going to take out treble, bass, and aux as they dont work on my system, but i figured it may for some others so i left it in since it fit ok.
        I have create a mixer for Carwings but when i use the command
        B01,56,73,36,37,"VOL+;FREQ1","" the frequence down and not up .
        Same problem for all buttons.
        This is my mixer.skin file:
        Code:
        RoadRunner Skin
        RRScreen mixer
        IMG,89,18,130,38,"mixer.png"
        INC,Bottomtext.txt
        L,233,18,333,38,0,0,0,18,"Arial","AUDIOTRACK","SCROLL-LEFT"
        B,6,8,75,52,"MINIMIZE",
        B,674,9,118,52,"EXIT",
        B,544,543,67,57,"MIXER",@SKIN@,
        B,478,543,66,56,"SHUFFLE",
        B,410,543,67,57,"MUTE",
        B,341,543,67,57,"PLAY",
        B,273,543,67,57,"NEXT",
        B,206,543,67,57,"PREV",
        B,138,543,67,57,"VOL-",
        B,65,543,72,57,"VOL+",
        I,418,554,47,33,"MUTE:b"
        I,624,9,47,53,"PHONE_CONNECTED_PHOCO"
        I,572,12,50,45,"ONLINE"
        B02,95,73,36,37,"VOL+;FREQ2",""
        B03,135,74,36,37,"VOL+;FREQ3",""
        B04,174,73,36,37,"VOL+;FREQ4",""
        B05,213,72,36,37,"VOL+;FREQ5",""
        B06,253,72,36,37,"VOL+;FREQ6",""
        B07,295,72,36,37,"VOL+;FREQ7",""
        B08,334,72,36,37,"VOL+;FREQ8",""
        B09,375,72,36,37,"VOL+;FREQ9",""
        B10,727,72,36,37,"VOL+;FREQ18",""
        B10,688,72,36,37,"VOL+;FREQ17",""
        B10,648,72,36,37,"VOL+;FREQ16",""
        B10,610,72,36,37,"VOL+;FREQ15",""
        B10,571,72,36,37,"VOL+;FREQ14",""
        B10,532,72,36,37,"VOL+;FREQ13",""
        B10,492,72,36,37,"VOL+;FREQ12",""
        B10,455,72,36,37,"VOL+;FREQ11",""
        B10,415,72,36,37,"VOL+;FREQ10",""
        B11,54,270,36,37,"VOL-;FREQ1",""
        B12,95,270,36,37,"VOL-;FREQ2",""
        B13,136,270,36,37,"VOL-;FREQ3",""
        B14,174,270,36,37,"VOL-;FREQ4",""
        B15,214,270,36,37,"VOL-;FREQ5",""
        B16,254,270,36,37,"VOL-;FREQ6",""
        B17,294,270,36,37,"VOL-;FREQ7",""
        B18,334,270,36,37,"VOL-;FREQ8",""
        B19,375,270,36,37,"VOL-;FREQ9",""
        B20,613,270,36,37,"VOL-;FREQ15",""
        B20,729,270,36,37,"VOL-;FREQ18",""
        B20,690,270,36,37,"VOL-;FREQ17",""
        B20,653,270,36,37,"VOL-;FREQ16",""
        B20,574,270,36,37,"VOL-;FREQ14",""
        B20,535,270,36,37,"VOL-;FREQ13",""
        B20,493,270,36,37,"VOL-;FREQ12",""
        B20,454,270,36,37,"VOL-;FREQ11",""
        B20,414,270,36,37,"VOL-;FREQ10",""
        B21,47,313,50,34,"VOL+;MASTER",""
        B22,105,313,50,34,"VOL+;BASS",""
        B23,165,314,50,33,"VOL+;TREBLE",""
        B24,225,313,50,34,"VOL+;WAVE",""
        B25,285,312,50,35,"VOL+;LINE IN",""
        B26,345,313,50,35,"VOL+;CD Audio",""
        B27,405,314,50,33,"VOL+;AUX",""
        B28,465,314,50,33,"VOL+;WINAMP",""
        B29,585,313,50,34,"VOL+;PREAMP",""
        B30,705,313,50,34,"VOL+;BALANCE",""
        B31,45,495,50,40,"VOL-;MASTER",""
        B32,105,495,50,40,"VOL-;BASS",""
        B33,165,495,50,40,"VOL-;TREBLE",""
        B34,225,495,50,40,"VOL-;WAVE",""
        B35,285,495,50,40,"VOL-;LINE IN",""
        B36,345,495,50,40,"VOL-;CD audio",""
        B37,405,495,50,40,"VOL-;AUX",""
        B38,465,495,50,40,"VOL-;WINAMP",""
        B39,585,495,50,40,"VOL-;PREAMP",""
        B40,705,495,50,40,"VOL-;BALANCE",""
        S11,62,348,20,146,60,322,20,146,V,01,"pointer.png",20,"MASTER","Master"
        S12,122,348,20,146,115,324,20,146,V,01,"pointer.png",20,"BASS","Bass"
        S13,183,348,20,146,180,324,20,146,V,01,"pointer.png",20,"TREBLE","Treble"
        S14,242,348,20,146,240,324,20,146,V,01,"pointer.png",20,"WAVE","Wave"
        S15,302,348,20,146,300,324,20,146,V,01,"pointer.png",20,"LINE","Line"
        S16,362,348,20,146,360,324,20,146,V,01,"pointer.png",20,"CD","CD"
        S17,423,348,20,146,420,324,20,146,V,01,"pointer.png",20,"AUX","Aux"
        S18,482,348,20,146,480,324,20,146,V,01,"pointer.png",20,"WINAMPVOL","Wamp Vol"
        S19,602,348,20,146,600,324,20,146,V,01,"pointer.png",20,"PREAMPVOL","Wamp preamp"
        S20,722,348,20,146,721,324,20,146,V,01,"pointer.png",20,"BALANCE","Balance"
        S11,61,115,24,152,53,378,032,174,V,01,"pointer.png",015,"FREQ1","55Hz"
        S12,101,115,24,152,92,378,032,174,V,01,"pointer.png",015,"FREQ2","77Hz"
        S13,142,115,24,152,132,378,032,174,V,01,"pointer.png",015,"FREQ3","110Hz"
        S14,180,115,24,152,171,378,032,174,V,01,"pointer.png",015,"FREQ4","156Hz"
        S15,219,115,24,152,211,378,032,174,V,01,"pointer.png",015,"FREQ5","220Hz"
        S16,260,115,24,152,251,378,032,174,V,01,"pointer.png",015,"FREQ6","311Hz"
        S17,300,115,24,152,293,378,032,174,V,01,"pointer.png",015,"FREQ7","440Hz"
        S18,339,115,24,152,333,378,032,174,V,01,"pointer.png",015,"FREQ8","622KHz"
        S19,383,115,24,152,372,378,032,174,V,01,"pointer.png",015,"FREQ9","880Hz"
        S20,421,115,24,152,411,378,032,174,V,01,"pointer.png",015,"FREQ10","1.2KHz"
        S21,461,115,24,152,450,378,032,174,V,01,"pointer.png",015,"FREQ11","1.8KHz"
        S22,500,115,24,152,490,378,032,174,V,01,"pointer.png",015,"FREQ12","2.5KHz"
        S23,540,115,24,152,529,378,032,174,V,01,"pointer.png",015,"FREQ13","3.5KHz"
        S24,580,115,24,152,569,378,032,174,V,01,"pointer.png",015,"FREQ14","5KHz"
        S25,621,115,24,152,610,378,032,174,V,01,"pointer.png",015,"FREQ15","7KHz"
        S26,659,115,24,152,650,378,032,174,V,01,"pointer.png",015,"FREQ16","10KHz"
        S27,695,115,24,152,690,378,032,174,V,01,"pointer.png",015,"FREQ17","14KHz"
        S28,736,115,24,152,730,378,032,174,V,01,"pointer.png",015,"FREQ18","20KHz"
        B02,1,80,52,56,"PRESET;Rock||SETVAR;EQPreset;$Rock$||SAVETOSkin;EQPreset;0||SetRock",
        L,4,408,42,20,255,255,255,10,"Arial:B","=Phone","center"
        L,6,346,39,20,255,255,255,10,"Arial:B","=Jazz","center"
        L,3,281,46,20,255,255,255,10,"Arial:B","=Classic","center"
        L,6,219,39,20,255,255,255,10,"Arial:B","=Rap","center"
        L,6,158,39,20,255,255,255,10,"Arial:B","=Pop","center"
        L,6,96,39,20,255,255,255,10,"Arial:B","=Rock","center"
        B03,4,141,50,56,"PRESET;Pop||SETVAR;EQPreset;$Pop$||SAVETOSkin;EQPreset;1||SetPop",
        B04,4,203,50,56,"PRESET;Rap||SETVAR;EQPreset;$Rap$||SAVETOSkin;EQPreset;2||SetRap",
        B05,4,265,50,56,"PRESET;Classical||SETVAR;EQPreset;$Classical$||SAVETOSkin;EQPreset;3||SetClassical",
        B06,4,327,50,56,"PRESET;Jazz||SETVAR;EQPreset;$Jazz$||SAVETOSkin;EQPreset;4||SetJazz",
        B07,4,390,50,56,"PRESET;Phone||SETVAR;EQPreset;$Phone$||SAVETOSkin;EQPreset;5||SetPhone",
        END
          [QUOTE=pierrotm777;1352647]I have create a mixer for Carwings but when i use the command
          Check that you have the latest Foobar player DLL - there used to be an issue with resizing the EQ causing the player not to adjust the volume up/down correctly.
          Ride Runner RR's Myspace
            also if this is to be used for just foobar then you dont need the preamp slider as there is no preamp in foobar.
              Thanks bratnetork ,
              I use it also for all player because i have always a NAVPAUSE,NAVRESUME problem with foobar and itunes,not have with winamp and wmp.
                [QUOTE=guino;1352675]
                Ah, ok , i test that .
