Create 5 commands in a screen who call an autoit exe
  • Create 5 commands in a screen who call an autoit exe
    Hi,
    I have a little programme autoit (thanks again John) with 5 commands
    _WHEELUP()
    _WHEELDOWN()
    _CLICKRIGHT()
    _SLIDEON()
    _SLIDEOFF
    Who call:
    Code:
    Func _WHEELUP()
    	WinActivate ($WindowsName)
    	MouseMove(500, 300, 10)
    	MouseWheel("up", 5)
    EndFunc
    Func _WHEELDOWN()
    	MouseWheel("down", 5)
    EndFunc
    Func _CLICKRIGHT()
    	MouseClick("right", 500, 300, 1, 10)
    EndFunc
    Func _SLIDEON()
    	MouseClick("left", 380, 80, 1, 10)
    EndFunc
    Func _SLIDEOFF()
    	MouseMove(5, 80)
    	MouseClick("left", 5, 80, 1, 10)
    EndFunc
    In a screen I have defines 5 buttons:
    Code:
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B08,269,543,64,64,"","Mouse Right"
    B08,336,542,64,64,"WHEELDOWN","Roll Down"
    B08,73,543,64,64,"WHEELUP","Roll Up"
    B08,138,544,64,64,"","Mouse Left"
    B08,204,543,64,64,"CLICKRIGHT","Right Click"
    In my autoit exe i have some test but don't run :
    Code:
    		If  $rr.GetInfo("WHEELUP") Then _WHEELUP()
    		If  $rr.GetInfo("WHEELDOWN") Then _WHEELDOWN()
    		If  $rr.GetInfo("CLICKRIGHT$")  Then _CLICKRIGHT()
    		If  $rr.GetInfo("SLIDEON$") Then _SLIDEON()
    		If  $rr.GetInfo("SLIDEOFF") Then _SLIDEOFF()
    Who can help me and say me what i must to do .
    48 readings and nobody can help me ?
    Please who can take some time for to help me ?
      http://www.mp3car.com/vbulletin/road...t-program.html
      Some of the code in that thread is available with the SDK examples provided with the installer. All you have to do is add that code from post #5 of that thread, then where there's the "this"/"that" you'll compare the cmd received with a command to execute each of your 5 functions. Then on the RR side you'll use the SENDMSG;Receiver;<COMMAND> on each button you made (so it executes each corresponding function in the autoit script). That thread shows an alternate way of doing things too, but what I just described is likely the best choice.
      Should look like this (UNTESTED):
      Code:
      Global Const $StructDef_COPYDATA = "ptr;dword;ptr"
      Global Const $WM_COPYDATA = 0x4A
      Global Const $WM_CLOSE = 0x10
      Global Const $STRUCTDEF_AU3MESSAGE = "char[255]"
      Dim $cmd
      ; Create Reciver window
      $hwmd_Reciver = GUICreate("PierReceiver")
      ; Register Windows Messages
      GUIRegisterMsg($WM_COPYDATA, "_GUIRegisterMsgProc")
      GUIRegisterMsg($WM_CLOSE, "_GUIRegisterMsgProc")
      ;Loop indefinitely - put your commands in here
      While 1
      If $cmd = "WHEELUP" Then
        $cmd = ""
        _WHEELUP()
      Endif
      If $cmd = "WHEELDOWN" Then
        $cmd = ""
        _WHEELDOWN()
      Endif
      If $cmd = "CLICKRIGHT" Then
        $cmd = ""
        _CLICKRIGHT()
      Endif
      If $cmd = "SLIDEON" Then
        $cmd = ""
        _SLIDEON()
      Endif
      If $cmd = "SLIDEOFF" Then
        $cmd = ""
        _SLIDEOFF()
      Endif
      Sleep(250)
      WEnd
      ; Message Handler
      Func _GUIRegisterMsgProc($hWnd, $MsgID, $WParam, $LParam)
      	If $MsgID = $WM_COPYDATA Then
      		; We Recived a WM_COPYDATA Message
      		; $LParam = Poiter to a COPYDATA Struct
      		$vs_cds = DllStructCreate($StructDef_COPYDATA, $LParam)
      		; Member No. 3 of COPYDATA Struct (PVOID lpData;) = Pointer to Costum Struct
      		$vs_msg = DllStructCreate($STRUCTDEF_AU3MESSAGE, DllStructGetData($vs_cds, 3))
      		$SciTECmdLen = DllStructGetData($vs_cds, 2)
      		$cmd = StringLeft(DllStructGetData($vs_msg, 1), $SciTECmdLen)
      		; Display what we have recived
      		; MsgBox(0, "Test String", $cmd)
      	ElseIf $MsgID = $WM_CLOSE Then
      	; We Recived a WM_CLOSE Message
      		Exit
      	EndIf
      EndFunc ;==>_GUIRegisterMsgProc
      In RR:
      Code:
      B08,336,542,64,64,"SENDMSG;PierReceiver;WHEELDOWN","Roll Down"
      B08,73,543,64,64,"SENDMSG;PierReceiver;WHEELUP","Roll Up"
      B08,204,543,64,64,"SENDMSG;PierReceiver;CLICKRIGHT","Right Click"
      Ride Runner RR's Myspace
        Code:
        Dim $cmd
        While 1
          $cmd = ""
          _WHEELUP()
        Endif
          $cmd = ""
          _WHEELDOWN()
        Endif
          $cmd = ""
          _CLICKRIGHT()
        Endif
          $cmd = ""
          _SLIDEON()
        Endif
          $cmd = ""
          _SLIDEOFF()
        Endif
        Sleep(250)
        WEnd
        ; Message Handler
        		Exit
        	EndIf
        In RR:
        Code:
        Thank you very much Guino, I try that.
        Thanks you very much.
