Repeat command on button hold
  • Repeat command on button hold
    I'm using COM objects to communicate between RR and Fusion Brain MDX. For my power mirror control pressing the button sends the command that pulses a FB output. Can holding a button send a command over and over again until it is released? At the moment I have to tap, tap, tap my button to make large changes in mirror position.
    Code:
    /, Fusion Control Centre
    X,FusionCOM
    L,134,524,65,25,0,0,0,14,"Verdana:B","fusion_varnum_0_1","RIGHT"
    L,20,524,58,25,0,0,0,14,"Verdana:B","fusion_varnum_11_1","RIGHT"
    INC,Bottomtext.txt
    L3,1025,0,5,5,255,255,255,12,#DFXFont#,"=.",
    B05,626,192,63,73,"fusion_vote_Passdown",
    B05,244,190,63,73,"fusion_vote_Drivdown",
    B05,624,116,63,73,"fusion_vote_Passup",
    B05,245,116,63,73,"fusion_vote_Drivup",
    B05,311,160,89,60,"fusion_vote_Drivin",
    B05,151,161,89,60,@fusion_vote_Drivout@,
    B,538,158,84,63,"fusion_vote_Passin",
    B,697,158,84,63,"fusion_vote_Passout",
    There are only a few commands that are automatically "re-executed" when you press and hold a button. Here's the list:
    PGUP, PGDOWN, RRPREV, RRPREV2, RRNEXT, AUDIOPREV, AUDIONEXT, SLIDER, FREQ+, FREQ-, TUNEUP, TUNEDOWN, FINEUP, FINEDOWN, BROWSE, ZOOM+, ZOOM-, WEBDOWN, WEBUP, SELECT+, CTRLRIGHT, CTRLLEFT, CTRLUP, CTRLDOWN, FFWD, FRWD also anything starting with VOL
    One suggestion would be for you to make the button start the motion when pressed and stop the motion when you press it again. This can be done with SETVAR and a timer event.
    Another possibility is for you to use one of the repeat codes (from the list above) and override the command executed on that specific screen using exectbl.ini. Since you only need 8 commands, this should be simple enough (plus you may be able to use as many VOL commands as needed). For instance:
    B05,626,192,63,73,"VOLPD",""
    B05,244,190,63,73,"VOLDD",""
    B05,624,116,63,73,"VOLPU",""
    B05,245,116,63,73,"VOLDU",""
    B05,311,160,89,60,"VOLDI",""
    B05,151,161,89,60,"VOLDO",""
    B,538,158,84,63,"VOLPI",""
    B,697,158,84,63,"VOLPO",""
    Then in ExecTBL.INI (Be sure to replace myscreen.skin with the name of the .skin file):
    "VOLPD","fusion_vote_Passdown",myscreen.skin
    "VOLDD","fusion_vote_Drivdown",myscreen.skin
    "VOLPU","fusion_vote_Passup",myscreen.skin
    "VOLDU","fusion_vote_Drivup",myscreen.skin
    "VOLDI","fusion_vote_Drivin",myscreen.skin
    "VOLDO","fusion_vote_Drivout",myscreen.skin
    "VOLPI","fusion_vote_Passin",myscreen.skin
    "VOLPO","fusion_vote_Passout",myscreen.skin
    Let me know how that goes..
    Ride Runner RR's Myspace
      Thanks again Guino. I used the last method.
      Mirror.skin
      Code:
      B05,152,161,89,60,"VOLDO",""
      ExecTBL.ini
      Code:
      /ACCLR8N's repeat on hold buttons
      "VOLDO","fusion_vote_Drivout",Mirror.skin
      "VOLDI","fusion_vote_Drivin",Mirror.skin
      "VOLDU","fusion_vote_Drivup",Mirror.skin
      "VOLDD","fusion_vote_Drivdown",Mirror.skin
      "VOLPO","fusion_vote_Passout",Mirror.skin
      "VOLPI","fusion_vote_Passin",Mirror.skin
      "VOLPU","fusion_vote_Passup",Mirror.skin
      "VOLPD","fusion_vote_Passdown",Mirror.skin
        I assume you used it AND it worked ? While this is a nice workaround, I should probably make some "documented" way to do it.
          Yes, works fine. What don't you like besides controlling the "volume" of my mirror positions? I don't expect this code to be used very often.
          The plus and minus buttons on the Carwings mixer skin don't work for the "CD". Do I use this to correct that as well?
            On the Car Wings skin the code "VOL+;CD Audio" is used, if your "CD" line is not called "CD Audio" then you may have to rename that to whatever it is. You can check the name of your CD line in the Windows Mixer or in Debug.txt.
              Now that's thinking outside the box for sure...
              Next in line: RRMedia v2.0
              DFX 5.1.1 Skin
              Appstore Link
              My RideRunner Plugins
              RRMedia
              RRExtended
              DFXVoice
                i need to do something similar..
                i need to send a command to RR to start raising the volume and stop raising it when another command is sent..
                any ideas how to do that with setvar ??
                  Yes, I have created loops in rrcode before using the exectbl. I can post a sample code latter when I get home.
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    thanx blue i would appreciate that..
                    i just need to simulate that constant press of the vol+ and vol- buttons
                      why not use the "startvol+", "startvol-", "stopvol" commands ?
                      [master volume only]
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        i never heard of those ..
                        how do u use them?
                        "startvol+;master" ?
                        did u just add those commands cause they are not documented anywhere
                        i will check as soon as i go home
                        EDIT: Ok they work like a charm..this is perfect.. thanks Mitch
                          see, just says i pay attention to you
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Must have been Extreamly NEW, like times Mitch says "I didn't change anything"...mean while, a bit latter, in comes a RR svn update from the a fore mentioned RR dev team member, refixing said problem of which he "didn't" change... heheh
                            DFX 5.1.1 Skin
                            Appstore Link
                            RRMedia
                            RRExtended
                            DFXVoice
                              Guess that's a good thing that Mitch was listening bc my solution was only good for x times of looping as it wouldn't allow ANY cmds till it was done with the loop
                              DFX 5.1.1 Skin
                              Appstore Link
                              RRMedia
                              RRExtended
                              DFXVoice
