RR/DFX4 Gauges Stats?
  • RR/DFX4 Gauges Stats?
    Hi, I'm new to RR planning on switching over from Media Engine. I am using DFX4. I got all the buttons and menu setup the way I want but I am still having a problem.
    I can't seem to get GAUGES STATS to work. Can anyone tell me how to get the satellites and speedo to work with my gps?
    Currently connected through bluetooth. Detectable and connected through both Windows XP and Garmin Mobile PC. Where and what files do i have to alter to setup the com port for Gauges Stats?
    Second thing is, which plugin works for Blackberry phones? At least the basic dial/answer through bluetooth.
    Thank you,
    Are you using some kind of GPS com port splitter, like XPORT ?
    If not you need to set up the physical port to XPort, and then virtual ports for RR / DFX and for your GPS program.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
      Ok, i now got xport... now what?
        Run Xport. I believe it sets itself up to run automatically on startup from now on.
        Set your GPS port on the left side to your actual physical port. Then set up the right side to connect to your GPS program and RR.
        For example port 3 for the physical port, and 4 and 5 for your GPS and RR. Then Set your GPS program to port 4 and in RR Config set RR to port 5.
          ah ic ic, but, where do i set the RR gps port? i didnt see it in rrconfig
            it'll be in the rrconfig
            under the GPS section - under the 'Other' portion
            03 Hyundai Elantra GT {Worklog}
            HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
            RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
            cmdRR tall skin creator
            86 Pontiac Fiero SE 2m6
            possible carpc install
              sweet! thanks! got it working now!
