Need Help with slider in a screen
  • Need Help with slider in a screen
    Hello all,
    I don't understand why i can't use my slider with the mouse or the finger !
    This is my screen's lines:
    Code:
    RoadRunner Skin
    RRScreen "GoogleMapsTrackFrom"
    GoogleMapsTrackList_off.png,GoogleMapsTrackList_off.png,GoogleMapsTrackList_on.png,GoogleMapsTrackList_down.png
    /POSX=10
    /POSY=90
    [Labels]
    L,182,374,49,31,255,255,255,25,"Webdings","=6","center",,"DS=2,2,0,0,0"
    L,258,374,49,31,255,255,255,25,"Webdings","=5","center",,"DS=2,2,0,0,0"
    L,52,383,49,20,255,255,255,14,"Arial","=OK","center",,"DS=2,2,0,0,0"
    [Buttons]
    B,244,378,70,30,"UP",
    B,170,378,70,30,"DOWN",
    B,1,378,153,30,"SENDMSG;GoogleMapsTrack;TRACKFROM||TRACKFROM",
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S,296,6,17,364,524,24,41,259,V,0,"mixersliderH.png",20,"CLSLIDER",
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,CL,transparent.bmp,sel.bmp,end.bmp,0,50,60
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    SC,10,8,280,362,255,255,255,0,0,0,0,0,0,255,255,255,true,20,"Lucida Sans Unicode"
    END
    If i want to use ElcosMenu or FlytoMenu , i don't see nothing into the screen
    I use this menu with these exectbl.ini lines:
    Code:
    /***************************************GOOGLE MAPSTRACK**********************************
    "SELECTTRACKFROM","CLCLEAR;ALL||MENU;GoogleMapsTrackFrom.skin||CLLOAD;$SKINPATH$Scripts\GoogleMapsTrack\TRACKLIST.txt;TRUE||SETLIST;12"
    /"SELECTTRACKFROM","CLCLEAR;ALL||RUN;$SKINPATH$Flytomenu.exe|GoogleMapsTrackFrom.skin||CLLOAD;$SKINPATH$Scripts\GoogleMapsTrack\TRACKLIST.txt;TRUE||SETLIST;12"
    "TRACKFROM","SETVARBYCODE;TRACKFROM;LISTTEXT||SETVAR;TRACKFROM;$TRACKFROM$||SENDMGS;GoogleMapsTrack;TRACKFROM||WAIT;0.5||EXIT"
    "ONCLCLICK","SENDMGS;GoogleMapsTrack;TRACKFROM",GoogleMapsTrackFrom.skin
    Thanks for your help
    THe sliders do not work in elcos or flytomenu.
    You can use a wiper in flyto. Basically the same thing but it will not show an image at a positon as a slider would. Similar to a scrubber on centrafuse.
    New Age Garmin - Skin for RR
      Hi
      Is there any chance to make sliders work whit ElcosMenu or whit FlyToMenu?
      Thanke for your help
      Regard
