Labels with 2nd font size value
  • Labels with 2nd font size value
    I use Byind cmd alot, but I Was wondering if its possiable at this present time or is a esay add to RR , to have a 2nd font size in the label cmd line
    basically i'm after whats in Red to have its own Font size value
    L,xx,xx,xx,xx,255,255,255,20,"ARIAL","BYIND;SHIFTL OCK;=1<<=!","CENTER"
    Thank you and Enjoy
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Each label has a defined/set font, size and color -- currently that can't be changed on the fly.
    The good news is you can stack labels on top of each other, so you can do this:
    L,xx,xx,xx,xx,255,255,255,22,"ARIAL:B","BYIND;SHIF TL OCK;=<<=!","CENTER"
    L,xx,xx,xx,xx,255,255,255,20,"ARIAL","BYIND;SHIFTL OCK;=1<<=","CENTER"
    So the "!" shows on font 22 bold while the "1" shows font 20 and normal.
    Ride Runner RR's Myspace
      thats what i thought cheers G for comfirming
        Hello
        I think i have nearly the same problem. i want to switch a label between (tagtitle) and (currenttime - tracktime)
        here is my code, but RR shows only currenttime
        B08,255,550,556,50,"IFVAR;TAGTIME=1;SETVAR;TAGTIME ;0||SETLABELCODEID;L08;TAGTITLE<<SETVAR;TAGTIME;1| |SETLABELCODEID;L08;CURRENTTRACKTIME||= - ||TRACKTIME"
        L08,255,550,556,50,0,124,195,26,"Arial:B","TAGTITL E","SCROLL-CENTER",,"DS=1,1,220,220,220"
        RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
        RR-Plugin: IBusCommunicatoRR new Updates
          here is my solution. only change || to ++ and it works:
          B08,255,550,556,50,"IFVAR;TAGTIME=1;SETVAR;TAGTIME ;0||SETLABELCODEID;L08;TAGTITLE<<SETVAR;TAGTIME;1| |SETLABELCODEID;L08;CURRENTTRACKTIME++= - ++TRACKTIME"
