Sliders and Autoit script
  • Sliders and Autoit script
    Hello all,
    I try to undertand how the slider run with autoit.
    Into my screen , i have these lines:
    Code:
    /Slider verticaux
    Y02,"DistanceSliderImages\SLIDER_*.png"
    S02,185,316,35,223,545,75,35,30,V,02,"",015,"!DISTANCESLIDER",""
    I look for an autoit example , how to program .
    If i understand the variable must to go from 0 to 65536
    So, if my autoit is $distance and go from 0 to 500 (by example)
    What i do to write .
    Thanks for all help !
    You'll have to do a conversion from the 0-500 range into the 0-65536 range.. you just set:
    DISTANCESLIDER = $DISTANCE * 137.05 ( 65536/500 = 137.05 or 500 steps of 137.05)
    Then you just do SETVAR with the DISTANCESLIDER value.
    Ride Runner RR's Myspace
      Cool Guino,
      I try that as soon as possible !
        I have tried that but nothing !
        Code:
        $rr.execute("SETVAR;!DISTANCESLIDER;"&$distance * 137.05 )
        I have tried also that without success !
        Code:
        $rr.execute("SETVAR;!DISTANCESLIDER;10000")
          Who can say me why $rr.getinfo("isunits") don't return me True or False?
            "isunits" is a variable/setting not a label code, so you should use: $rr.getinfo("=$isunits$")
            for the slider, you need to define a variable slider like:
            Code:
            /Slider verticaux
            S02,185,316,35,223,545,75,35,30,V,02,"",015,"$DISTANCESLIDER$",""
            THEN you can use SETVAR with it:
            $rr.execute("SETVAR;DISTANCESLIDER;10000")
            $rr.execute("SETVAR;DISTANCESLIDER;"&$distance * 137.05 )
              Code:
              /Slider verticaux
              Thanks Guino, It's cool
