how do I run a batch file with a command variable?
  • how do I run a batch file with a command variable?
    I just cant figure it out. I've made a simple batch file which connects to a ftp-server and uploads a given file. I've made a button in RR which runs the batch file with the variable PICTURE after. ANd I've made a label in RR to see that the PICTURE variable contained a useful path and filename.
    cmd:
    "RUN;C:\fennec\up.bat|$PICTURE$"
    isn't that supposed to work? it launches the batch file but I cant get any output from RR on the variable.
    so what I want is
    c:\fennec\up.bat d:\images\test.jpg
    and what i get is
    c:\fennec\up.bat
    halp?
    btw: ive made absolutely sure the batch file works when running it via cmd and supplying it with the image path/file.
    batch for referance
    @echo off
    set ftp_user=myuser
    set ftp_pass=mypass
    set ftp_server=mysite
    set ftp_upload_path=mypath
    echo user %ftp_user%> temp_info.dat
    echo %ftp_pass%>> temp_info.dat
    echo cd %ftp_upload_path%>>temp_info.dat
    echo bin>> temp_info.dat
    echo put %1>> temp_info.dat
    echo quit>> temp_info.dat
    ftp -n -s:temp_info.dat %ftp_server%
    del temp_info.dat
    exit
      Where do you SET the variable?
      You need to set it first to have it available.
      "SETVAR;PICTURE;d:\images\test.jpg||C:\fennec\up.b at|$PICTURE$"
      After you push this button, you should see the variable in a label with this code.
      "=$PICTURE$"
        I just used this info from skin commands.txt
        "PICTURE" - Shows the full path to the current picture of the picture viewer
        when I set up a label with cmd "PICTURE" it has no trouble showing the path to the selected picture. I just thought it should work with a button as well.
          *facepalm*
            Code:
            "SETVARBYCODE;PICTURE;PICTURE||RUN;C:\fennec\up.bat|$PICTURE$"
            should work.
            Ride Runner RR's Myspace
              Yeah, I just didn't know you had to do the set picture from picture thingie.
              Works now, thanks to all
