Need help around the variable ALBUMART
  • Need help around the variable ALBUMART
    In my last script for RR, i have a label, =$webradiopic$ :
    Into my skin file:
    Code:
    /, I, x, y, w, h, Code;INDICATORCODES
    I,11,390,146,136,"FILE;$skinpath$Scripts\WebRadio\Pics\$WebRadioPic$","all"
    In my autoit script , i write that:
    Code:
    $rr.execute("SETVAR;WEBRADIOPIC;"& $_LastUkTopChartsListArray[$_P] & '.jpg')
    who run well with this result:
    and that:
    Code:
    $rr.execute("SETVAR;ALBUMART;"& $_LastUkTopChartsListArray[$_P] & '.jpg')
    who don't run
    I want see into the ALBUMART fence my pic who are defined into $webradiopic$.
    How can i write that in autoit
    I should like to set the ACTIVESOURCE variable with WebRadio in place from Audio or Radio
    setvar;ACTIVESOURCE;WebRadio don't run .
    All help is welcome !
    albumart is not a var , and you can't change activesource ,
    use your own var for albumart and just change the var on source change ,
    ie ,,
    I,xx,xx,xx,xx,"$MYART$"
    so on source change ie audio , setvar;MYART;ALBUMART or for your radio setvar;MYART;WebRadioPic
    messy but you can use onscreenchange to set the vars on correct source or use activesource for the most and a onscreenchange for webradio
    Activesource cmd is there for all the basic sources audio,radio all of them , video , etc you can not make your own with activesource, you can use activesource to fire cmds and show labels
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      http://www.mp3car.com/vbulletin/road...ml#post1252014
      http://www.mp3car.com/vbulletin/road...ml#post1299770
