Visu with winamp 5.58
  • Visu with winamp 5.58
    On the councils of JohnWPB, i use now the last winamp version (5.58) with RR.
    And now the visu is very well embedded ! It's very cool .
    But, with my WebRadio script, the levels stay always down .
    I think that it's because the player is not winamp but Internet Explorer.
    It's an IE object in fact.
    Code:
    $oIE = _IECreate ( $_YoutubeSearch, 0, 0, 1 )
    Is it possible to configure RR for that ?
    Is your webradio an Internet Explorer Link that you're opening? If so, you'll need to find a visu plugin that uses the level from the soundcard output... there are only a few that do that, most of the visu plugins for winamp take the audio output of winamp alone for the visualizations.
    Ride Runner RR's Myspace
      Do you know some winamp's plugin that accept that ?
      If i understand , it's a winamp issu ? I use often the DFx4 AVS plugin . Is it possible to modified it ?
        I know there was one called G-Force that did that, but seems to be paid software now.
        This can probably be done using the line-in plugin and selecting "what u hear" as source of recording on the sound card -- but it may get complex if you have an audio input in the line in already (i.e. Sirius, etc).
          line-in plugin ? where i found that ?
            Ok, i understand, you speak about the 'line-input' winamp plugin !
            I have installed the 1.8 version.
            Do i set something into winamp to use it or i must just to install it !
              I wonder what the setting should be in windows 7. There is not a what-u-hear option there.
              Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
              Skin: MetroSex on the Beach preview
              07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
