Need help to embed my program
  • Need help to embed my program
    Hello,
    Into one of mine script, here RRTranslator, i create a windows 'English Dictionary' that i want to embed into a scpecific screen translator_definition.skin .
    My problem is that i don't create immediately this window (when translator.exe is launched) but just when i want this window.
    So , i have tried that but with an issue :
    Code:
    $GUIDef = GUICreate("English Dictionary", 600, 370)
    $Edit = GUICtrlCreateEdit("", 15, 15, 570, 300, BitOR($ES_AUTOVSCROLL, $ES_AUTOHSCROLL, $ES_READONLY, $ES_WANTRETURN, $WS_VSCROLL, $WS_HSCROLL))
    GUICtrlSetFont(-1, 13, 400, 0, "Arial")
    $Quit = GUICtrlCreateButton("Quit", 535, 330, 50, 25, $BS_DEFPUSHBUTTON)
    GUICtrlSetFont(-1, 10, 400, 0, "Arial")
    $TexttoTranslate = $rr.getinfo("=$TEXTTOTRANSLATE$");récupère le texte dont on veut une définition
    $sDefinitions = _GetDefinitions($TexttoTranslate);renvoie la définition
    GUISetState(@SW_SHOW,$GUIDef)
    $rr.execute("menu;translator_definition.skin;definition;$skinpath$Scripts\Translator\Translator.exe;English Dictionary")
    GUICtrlSetData($Edit, $sDefinitions)
    While 1
    	$msg = GUIGetMsg()
    	If $msg = $Quit Then
    		GUIDelete($GUIDef)
    		$rr.execute("ESC")
    		exitloop
    	EndIf
    WEnd
    As you can to see, i relaunch translator.exe,
    Code:
    but without that i want .
    Is it possible to write that:
    Code:
    $rr.execute("menu;translator_definition.skin;;;English Dictionary")
    How can i do to embed this windows please ?
    You don't have to relaunch the application.
    Try:
    Code:
    $rr.execute("menu;translator_definition.skin||run;;English Dictionary")
    This should work.
    Ride Runner RR's Myspace
      Originally posted by guino View Post
      This should work.
      This is my new code:
      Code:
      	If $cmd = "GETDEFINITION" Then;recherche d'une définition dictionnaire
      	  $cmd = ""
      	  	$Main = GUICreate("English Dictionary", 600, 370, -1, -1, BitOR($WS_SIZEBOX, $WS_MAXIMIZEBOX))
      		GUISetState(@SW_SHOW,$Main)
      	EndIf
      	If $cmd = "KILLDEFINITION" Then;fermeture de la fenêtre de définition
      	  $cmd = ""
      		GUIDelete($Main)
      		GUISetState(@SW_HIDE,$hwmd_Reciver)
      		$rr.execute("ESC")
      	Endif
      It's better but the GUI is not embedded into the translator_definition.skin correctly !
      Code:
      RoadRunner Skin
      RRScreen Translator
      Translator_Definition_Off.png,Translator_Definition_Off.png,Translator_Definition_On.png,Translator_Definition_Off.png
      A,63,57,600,370,
      IMG,21,10,65,41,"translator.png",all
      L,313,439,103,31,255,255,255,18,"Arial:B","=Back","CENTER",,"DS=2,2,0,0,0"
      L,107,18,605,25,255,255,0,18,"Arial","=$TitleDefinition$","LEFT",,"DS=,2,2,0,0"
      B,272,436,177,43,"SENDMSG;Translator;KILLDEFINITION",
      END
        I have found my issue. If i use a 'load' and not a 'menu' command, it's better !
        $rr.execute("menu;translator_definition.skin||run; ;English Dictionary")
        replaced by:
        $rr.execute("load;translator_definition.skin||run; ;English Dictionary")
        But the screen stay on the bottom task bar, and i need to click on the roadrunner to see my screen and the GUI well embedded !
