Embeded Pc navigator 10
  • Embeded Pc navigator 10
    Hi all
    Hope someone could help me embeded PC navigator 10,
    Because when i launch the program it self, the program open in the correct position and size, but when i go to my external_gps.skin in RR It opens fullscreen...
    /Martin
    Pc Napvivator Free
    I try that NOW !
      jep pc Navigator 10 free
        How do you change the size from full screen to 800x600 by example ?
          If you right click the Pc navigator icon and choose properties, then under destination you insert this bit after PC_Navigator.exe --window_border=no --window_position=0,53,800,427
          Example
          __________________________________________________ _________________________
          C:\Programmer\Navigator10_FREE\PC_Navigator\PC_Nav igator.exe --window_border=no --window_position=0,53,800,600
          window_position=Xpos,Ypos,Width,Height
          /Martin
            Ok ,
            I have tried that without success into the icon found on my desktop !
            Code:
            "D:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.exe --window_border=no --window_position=0,53,800,600"
            I have tried also to create a .bat without success !
              This is as close as i can get it at the moment
              in rr.ini
              GPS Path
              You still need to set your --window_position=
              window name
              !BarneyMainWndCls!Navigator
              in your gps skin file , copy your "A,xx,xx,xx,xx" and change to "C,xx,xx,xx,xx"
              Riderunner / Genesis
              Wifiman_NET:Version 1.0.0
                Originally posted by pierrotm777 View Post
                Ok ,
                Code:
                Worked fine for me.
                CAR: 2007 G35 Sport Coupe 5AT
                HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
                  Well now i have tried that and the only thing i get is, my topbar, and bottom bar and nothing where the Navigator should be..
                  My skin file:
                  RoadRunner Skin
                  RRScreen external_gps
                  external_gps_off.png,external_gps_off.png,external _gps_off.png,external_gps_off.png
                  C,0,51,800,356,
                  END
                  And my gps Settings in RR.ini:
                  [GPS]
                  gpsmode=2
                  mapmonkeypath=Click here to set path
                  gpspath=C:\Programmer\Navigator10_FREE\PC_Navigato r\PC_Navigator.exe --window_border=no --window_position=0,51,800,356
                  gpsname=!BarneyMainWndCls!Navigator
                  overspeed=55
                  gpsport=0
                  mappointmap=1
                  mapcountry=United States
                  mapcity=
                  mapautozoom=true
                  isunits=true
                  usegpsserv=false
                  gasfinderautorefresh=false
                    you need this as well
                    A,0,51,800,356,
                      Create a Navigator.skin and try that:
                      Code:
                      "Load;Navigator.skin;Navigator;C:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.exe --window_border=no --window_position=0,51,800,356;!BarneyMainWndCls!Navigator"
                      still no luck..
                      Skin file:
                      RoadRunner Skin
                      RRScreen navigator
                      C,0,51,800,429
                      END
                      Buttom from mainmenu:
                      B,310,333,182,149,"Load;navigator.skin;Navigator;C :\Programmer\Navigator10_FREE\PC_Navigator\PC_Navi gator.exe --window_border=no --window_position=0,51,800,429;!BarneyMainWndCls!Nav igator",
                        no forget all that for the moment , lets just get it working the correct way , before makeing things a bit more complictaed ....
                        add to your skin file
                        A,0,51,800,356,
                        then try , remove the this line for now
                        "Load;Navigator.skin;Navigator;C:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.e xe --window_border=no --window_position=0,51,800,356;!BarneyMainWndCls!Nav igator"
                          ok really simple Spoon feed
                          rrconfig
                          select external in GPS Mode
                          gpspath=C:\Programmer\Navigator10_FREE\PC_Navigato r\PC_Navigator.exe | --window_border=no --window_position=0,51,800,356
                          external_gps.skin
                          RoadRunner Skin
                          A,0,51,800,356,
                          C,0,51,800,356,
                          END
                          Menu Button
                          GPS
                          Nothing more , nothing else needed , unless you want to run more GPS app's
                            Nice... now everything is working... i am learning every day
                            Thx for the help...
                              because Nav10 is not truly embeded , at this point , when you press any rr button on the screen where the navi screen is , rr takes focus , and you lose nav10 , hence the "C" line this is a clipping area, basically cuts a hole in your skin file , so Nav10 can always be seen ....
