How do I choose a skin for RR?
  • How do I choose a skin for RR?
    I have lost patience for the time being with CF. Their direction in their product is not what I am looking for so I want to move on and try RR.
    From what I read there are basically 2 main options: DFX and Carwings. How do I decide which one to use or are they the same with just a different look?
    I get the impression that plugins are skin specific and not necesarily available for both. If that is the case, here are my priorities:
    I just did a fresh install of Windows 8 (dev copy) and Winamp Pro, CF is not installed and likely won't be unless I can't figure RR out.
    1. Sirius Radio with Mitch's adapter
    2. Good quality audio through optical out to an external X-fi card, no on board sound shaping required, I have an external processor.
    3. Garmin Mobile PC
    4. Voice commands and maybe BT phone if it will perform well enough (otherwise I will continue to use my Parrot) since I lucked out on one of those DS350 mics from ebay for $20
    5. Elm OBD
    6. Broadband wireless USB stick and Wifi for connectivity
    The rest is all gravy to me.
    Thanks in advance for the primer on RR!
    http://www.youtube.com/watch?v=b1yQiMTikWE
    I have issue with master volume. Because I not have sound driver for win8 I can't control master vol on RR skin.
    Other function work normal
    First. U need install .netframwork 3.5 and adobe flash player 10 ( 10 only ) before install RR.
      I got RR last night and I have Music and Sat Radio working great. Video works except for a few files.
        Can U control master volume on skin?
        Vol+, vol-
          Why is Elite 2 not an option? It has all the plugins you want. It's in "beta", but is fully functional.
          Live mp3Car Facebook Chat
            Wow...how did I miss that one, I guess I only looked at completed skins, not early releases. It looks as good as CF but should work. I'm all over it like a fat kid on a Twinkie, thanks for the heads up! Nothing like being a newb again at this
              Vol+, vol-
              Yes, I have the master working with my Griffin Power Mate.
              I am having trouble figuring out where to set up some of the other features. IE: Sirius works in Car Wings but I can't figure out how to add it to Elite so a button shows and works. Also GMPC opens when I select guidance but it does not embed. I'm not grasping the concept here on plugins. Do I need to D/L them somewhere for this specific skin and install or do I just need to alter setup somewhere in the settings?
              Any help would be appreciated. I guess I was spoon fed with "the market" in CF
                For embedding your GMPC into RR check out this previous thread...last post on the first page.
                http://www.mp3car.com/gps/119475-gar...-embedded.html
                Also check the first post on the top of page 8 of this thread here...
                http://www.mp3car.com/rr-faq/120598-...-runner-8.html
                VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
                Build 90% Apps 50% Install 10%
                  Try Reborn http://www.mp3car.com/rr-released-sk...7-25-11-a.html
                  Im very happy with it, and been using it in my car for 6 months now.
                  youtube pre version:
                  My Audi A4 car pc install
