Issue with IMG and indicator into an include file
  • Issue with IMG and indicator into an include file
    Hello,
    I try to include a file text (with only IMG and Indicators), into a screen with :
    My include file is:
    IMG,561,357,45,41,"$skinpath$button45x41_off.png", OUT
    IMG,561,357,45,41,"$skinpath$button45x41_on.png",O N
    IMG,561,357,45,41,"$skinpath$button45x41_down.png" ,DOWN
    I,567,364,32,27,"gmaps_trafficlayer",,,"Indicators \traffic_*.png"
    IMG,620,357,45,41,"$skinpath$button45x41_off.png", OUT
    IMG,620,357,45,41,"$skinpath$button45x41_on.png",O N
    IMG,620,357,45,41,"$skinpath$button45x41_down.png" ,DOWN
    I,626,364,32,27,"gmaps_bikelayer",,,"Indicators\bi cycle_*.png"
    IMG,678,357,45,41,"$skinpath$button45x41_off.png", OUT
    IMG,678,357,45,41,"$skinpath$button45x41_on.png",O N
    IMG,678,357,45,41,"$skinpath$button45x41_down.png" ,DOWN
    I,685,364,32,27,"gmaps_weatherlayer",,,"Indicators \temperature_*.png"
    IMG,738,357,45,41,"$skinpath$button45x41_off.png", OUT
    IMG,738,357,45,41,"$skinpath$button45x41_on.png",O N
    IMG,738,357,45,41,"$skinpath$button45x41_down.png" ,DOWN
    I,744,364,32,27,"gmaps_cloudlayer",,,"Indicators\c loud_*.png"
    My issue is that i use some .png file as indicators and i have a tranparence on the IMG buttons !
    Click image for larger version
    How can i change that please ?
    Thanks for your help !
    1st... does INClude file have anything to do with your issue?
    2nd... how about some real files, to allow people to evaluate
    3rd... most people have the images on the layers, my guess you're trying some dynamic building of buttons or something
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      I send you my skins files!
      I use the command 'setvar;includefile;RRGoogleMapsTools_Ind1.txt" or 'setvar;includefile;RRGoogleMapsTools_Ind2.txt' with a reloadscreen for update my screen !
        you didnt give me the indicators
        not to mention these are not RR indicators
        and, you didnt anwser my question, does "inc" have anything to do with the issue you are trying to solve?
        since i dont have the indicators, i cant really see much
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          i dont know what your trying to achive... but those things arnt defined as buttons... at least i dont see where
          a simplle change woyld be to change ",OUT" to ",ALL"
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            AS you can see into the main RRGoogleMapsTools.skin, the include is a variable ($includefile$):
            RideRunner Skin
            RRScreen RRGoogleMapsTools
            RRGoogleMapsTools_off.png,RRGoogleMapsTools_off.pn g,RRGoogleMapsTools_on.png,RRGoogleMapsTools_down. png
            INC,$includefile$
            I use the indicators as buttons here !
            I use the same screen for two differents Google Maps, so i need to set my variable with the first include or the second !
            My issue is that i use IMG for create a button picture !
            And if i add an indicator on this IMG picture, i have my issue !
            So, this issue not exist because i use the include option but because i use an IMG with an indicator on this IMG.
            I should have certainly this issue with the same code and without include !
            As i haven't a button code but an indicator, i think that i need only to have the first line for my pictures:
              sorry, i dont see any issue...
              i dont think the include has anything to do with it
              i just put one of your examples in the .skin file, and sure it draws the indicator with the the background
              thats how indicators work, you are applying images to layers, put your images on ALL layers
              not to mention they arent buttons, just images of buttons
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                I know why you don't see the issue.It's because this screen use the indicators that are defined into my last plugin RRGoogleMapsTools.
                So, without this plugin , the indicators are hidden
                  1st you never answered me, does it being in an include file mean anything...
                  2nd course i dont have your plugin, i just did:
                  in the RRGoogleMapsTools.skin file
                  Code:
                  IMG,561,357,45,41,"$skinpath$button45x41_off.png",ALL
                  IMG,561,357,45,41,"$skinpath$button45x41_on.png",ON
                  IMG,561,357,45,41,"$skinpath$button45x41_down.png",DOWN
                  I,567,364,32,27,"MUTE",,,"Icons\sirius.png"
                  and with the ALL, it draws correctly, and ill mention again, i dont see the point of ON and DOWN, thses IMG arnt defined as buttons in the skinfile...
                  so.. i dont know what your trying to achieve, i dont see anything i need to look at
                  your example is so based on your plugin, who knows, maybe the indicators are a problem in your plugin code.
                  i just used a standard RR indicator with an image
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    just change your "OUT" to "ALL" since these arnt skin objects of buttons anyway...
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Thanks mitchjs, i try that
                        Thanks mitchjs, this is exactly that i wanted !
