How to display the status of the GPS?
  • How to display the status of the GPS?
    How to display the status of the GPS?As the status of Bluetooth!
    You'll have to edit/create a skin which can display the GPS information or use a skin which already has a screen that displays the GPS information, then you just need to configure the GPS port in the config or rr.ini - however keep in mind that if you're using a nav application without splitting the serial port RR will not be able to display the information as the gps will be in use by the nav application. You could use XPort to split the port in that case (
    As for bluetooth, the only current solution is the .net bluetooth mobilephone plugin (
    Ride Runner RR's Myspace
