Custom Lists and CLIMG Command
  • Custom Lists and CLIMG Command
    ALL,
    I am designing a skin that is a little different than most. I'm trying to emulate drop down menus. The skins loads the menu.skin and when I click on an area the drop down menu appears and disappears after 3 sec (if inactive). To populate the dropdown menu, I've created a simple custom list (off screen) of my most frequently used sources and apps. Here is a quick sample:
    dropmenu.lst
    0
    LSTAUDIO||AUDIO
    LSTSIRIUS||SIRIUS
    and in the dropmenu.skin
    label code...
    L,80,50,140,45,255,255,255,14,"Verdana","CLDESC1", "left",
    L,80,95,140,45,255,255,255,14,"Verdana","CLDESC2", "left",
    button code...
    B,30,50,190,45,"SETVARBYCODE;CMDTXT;CLTEXT1||ESC|| $CMDTXT$",
    B,30,95,190,45,"SETVARBYCODE;CMDTXT;CLTEXT2||ESC|| $CMDTXT$",
    image code...
    IMG,30,50,45,45,"CLIMG1",all
    IMG,30,95,45,45,"CLIMG2",all
    The Labels and buttons work fine, but I cannot get the images to display. I've tried several different variations of the CODE to get them to display:
    1) CLIMGx with and without quotes
    3) $CLIMGx$ with and without quotes
    4) and lastly "SETVAR;CLIMGPATH;CLIMGx||$CLIMGPATH$"
    Some may wonder why I've decided not to use the custom list. Reason: this is a drop down menu and I need the labels and images to remain static without scrolling.
    Bobby
    CLSETIMG is a command and not a variable !
    "CLSETIMG" - This allows you to modify the image/icon of an item in the custom list. You specify the item number and
    the FULL path to the image to display for it. You CAN use $SKINPATH$ and other variables to reference the
    location of the image. NOTE: For iLists, the file MUST be in BMP format.
    Example: "CLSETIMG;5;C:\Icon1.BMP" (Sets the image for item 5 using Icon1.BMP in C:\)
    "CLSETIMG;5;$SKINPATH$ListIcon.BMP" (Sets the image using ListIcon.BMP from the skin folder)
      Thanks for the reply pierrotm777. I will try it out at lunch when I get home.
        The documentation give the "CLIMGx" syntax as with CLDESC and CLTEXT. I'll update my copy of the reference.
          Please read again my post #2 .The CLIMG command don't exist .You can to use the CLSETIMG command also or in fact the CLIMGx label ...
            Pierrotm777,
            Below is the reference I was trying to use:
            "CLIMG" The Image path from the selected item in the list. Optionally the item number can be specified:
            Example: "CLIMG5" or "CLIMG136" (Image path of the item 5 and 136 in the list)
            I do not want to set the image. They are already defined in the custom list. Basically, I'm trying to pull the contents of the list in 7 items increments without scrolling. So what I've done is define the list and show it offscreen and use the CLDESC (display label) and CLTEXT (button command) to execute the functions. I have it working with the labels and commands. I just wanted to display the images next to the label. If I were to use the list, it does show properly. Also, it says the images must be BMPs. Maybe that is my issues. Only PNGs are defined in the list. I will go back and save the PNGs as BMPs and see if something changes. I admit that what I'm doing is a bit duplicative. I just didn't want to go about re-coding everything when similar functionality is already there with the new Dynamic Menus. I'll post back if this works.
            Bobby
              Got it working just as I described. Each drop menu shows up to seven items. I set seven labels, image paths and cmd texts based off of the CLDESCx, CLIMGx and CLTEXT list codes. When I go to the next screen, I update a page variable and reloadscreen. Works like a charm. Drop menus are possible.
              Bobby
                amazing what RR can do... its so powerful, i forget what it does, and i work on it daily
                ok, not daily of late.. but a lot!
                love to see a little video
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  MitchJS,
                  Thanks for the comment. As soon as I finish the skin, I plan on putting it out for all to try out. I still have quite a few pagest to skin. Hopefully it'll qualify as a release someday.
