DFX and Navigator 11 free
  • DFX and Navigator 11 free
    ok, i searched and could not find an answer, please forgive me if this has been covered
    i have nav 11 free workking in RR with Carwings light skin fine, i installed DFX and now when i hit the nav button, nav 11 free comes up, but when i touch any buttons like next song or touch volume up or down, or the screen to bring up the nav menu, the nav screen disappears and i need to go back and hit the navigation button again
    i uninstalled DFX and it still works in carwings
    any idea what i need to set to make it work with DFX
    ok, i think i figured out how to explain this
    i dont think nav 11 is fully embedded into dfx, when i click on a button for volume, the windows focus goes to RR and nav 11 is running behind RR, how do i keep this from happening, if i click on the navigator box in the windows task bar it come back to the front
      I understood what you are talking about in the first post. I think this was also discussed in the dfx thread some weeks back. The reason is that rr is not properly embedding the gps window
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        Just what I thought. Any ideas on where I should look to fix it or is it a known issue and I need to find another nav program. I was using nav 11 cause its free and I'm cheap
        Sent from my ADR6300 using Tapatalk 2
          RR does properlly embedd the PC Navigator 11
          starting from RR 9/1/2012 there is support for it, including the settings in RRConfig, which are slightly complicated
          the DFX skin, PC Navigator isnt offically supported... at least not that i noticed, not yet at least
          to see it work, set it up in RRCONIFG...
          and use the "GPS" command to start
          not any existing button
          that will load "external_gps.skin"
          and embedd pcnav, course none of the functions will do anything, and dont push toggle layout, that will leave this screen
          the dfx5 developers if they choose can support pcnav 11
          im going to try to parent pcnav window to rr... but this isnt going help you
          with it in DFX5
          but a dirty way, since RR screen, a background of dfx is underneath the navigator, clip it out...
          add
          C,73,0,654,602,
          to DFX's "external_gps.skin"
          -Thanks
          Mitch
          www.rush2112.net
          Sun, Come shine my way
          Wind, Carry me home
          The piece of me that died
          Will return To live again
            with it in DFX5
            add
            C,73,0,654,602,
            ok, i dont quite understand those directions, is that to get it in DFX, i need more plain englis, as i am not a programmer and new to all this..
            even tho i dont understan them YET, as i have ALOT more learning to do, i do thank you for taking the time to post them, and i do appreciate RR and all the great work you have done on it!!!
              well, without a lot of skin work, since the dfx5 skin, is made for iguiance....
              but if u want simple.. edit the external_gps.skin
              add the line
              C,73,0,654,602,
              to then end of it
              then use "GPS" command to start it
              if you dont follow, best wait for DFX5 to offically support PCNavigator11 (and i dont know if its in the plans)
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                I undetsood all of that except the use gps command to start it.
                Looks like I got some reading to do on the gps command
                  "GPS" is a core RR command, to send it to rr... just use skintool
                  or even when RR is running type "GPS" with the qoutes! while at the menu...
                  im just saying i dont know if u can use any dfx menu, unless you can customize one to run the simple "GPS" command
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Thanks a lot mitchjs, you have been a great help, it. Was working great last night before windows updates, but now nothing works, I am uninstalling updates and hope I don't need to do a fresh install
                    Stupid me for not turning automatic updating off!!!!
                      i do updates all the time... doubt thats your issue
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
