Start button creation!?
  • Start button creation!?
    I would like to create a button on my home skin that will function exactly like pressing the start button in xp.....what is the command needed to get my new button to do so? I have posted a pic of my home screen with my windows button, and another pic of what i want the button to do....any help will be appreciated....thanks in advance
    The 1st image shows the home screen(the windows button is in the left corner).......the 2nd image shows the start menu after pressing the button(or at least what i want it to do.....this is the result when pressing the physical keyboard windows button, but i want the button on the skin to do the same, since i have a touchscreen
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    Also as you can see.....I'm using the elite lite skin. How can i make my new home skin the default skin when my PC boots up instead of the menu skin shown below?
      The start button can be called up with the keyboard shortcut of CTRL ESC
      so you can use a sendkey command followed by ^{ESC} as your button command.
      e.g.
      PHP Code:
      B
      ,000,050,200,050,"SENDKEY;^{ESC}",""
        e.g.
        PHP Code:
        B
        I copied ad pasted the command...but it did not work. Am I missing something in the command string? I looked up the key command for the windows button.....they are (LWIN) or (RWIN).....both will pull up the start menu just as they do on the physical keyboard......how is the command to be typed out so my onscreen button works is my problem....help!!!
          Does anyone know the command to make my onscreen button work? The button is supposed to act like the Start button on the windows task bar, but so far I can't get it to work......help!
            It's probably sending it to the application that has focus.
            Not sure how to get windows itself in focus.
              Try the keys Windows and D key.
                write a program
                here is one i whipped up in C# (.net 3.5)
                but autoit3 or c++ just a quick
                in the bin/release folder is the .exe
                just run it in RR
                Code:
                B,000,050,200,050,"RUNQ;SartMenu.exe,""
                (might want to put a path on it)
                RUNQ;$SKINPATH$Scripts\StartMenu.exe
                but you get the idea
                prob 100 other ways to do this...
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  Originally posted by mitchjs View Post
                  write a program
                  just run it in RR
                  Code:
                  I have downloaded your file....how do I set it up? I hope your solution works, and i will let you know if it does.....plus if it does I'm sure that others will use it also....so keep it posted....thanks in advance
                  I have upgraded to elite II....and i love it!!!! Here is my current Welcome screen and Entertainment screen(all of my screens are edited to feature the start menu button too! They All Also have the slider I added, but i only added a track time remaining label to the welcome screen only
                    Here is also a pic of the mobilephone.skin and icon I edited from elite lite to go with the elite II skin
                      write a program
                      here is one i whipped up in c# (.net 3.5)
                      just run it in rr
                      Code:
                      b,000,050,200,050,"runq;sartmenu.exe,""
                      runq;$skinpath$scripts\startmenu.exe
                      this startmenu.exe works great....but what command do i give the button to run it. It works as a menu option selction( the instructions to add menu buttons was perfect....but i want to run it from the windows button at the bottom of the skin window....so far nothing works.....help!!!!
                        i gave you the code....
                        EXAMPLE:
                        B,000,050,200,050,"RUNQ;SartMenu.exe",""
                        its just, RUNQ command
                        RUNQ;pathtoexe.exe
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          EXAMPLE:
                          RUNQ;pathtoexe.exe
                          This is how I entered the command in the button command box...
                          B,000,050,200,050,"RUNQ;C:\Program Files\RideRunner\Skins\eLite 2 (Default)\StartMenu.exe",""
                          Did not work...so then I tried.....
                          B,000,050,200,050,"RUNQ;C:\Program Files\RideRunner\Skins\eLite 2 (Default)\StartMenu\Startmenu.exe",""
                          Still did not work...then I tried.....
                          Did not work..then I tried.....
                          "RUNQ;C:\Program Files\RideRunner\Skins\eLite 2 (Default)\Startmenu.exe",""
                          Did not work...so my question is...how do I enter it so it will work??? I changed the elite 2 skin name to elite 2 (Default)...and I'm using the start menu exe program you created mitchjs and saved it to my skin folder...and it work great, so for now I am using it as a menu button selection till I solve my current issue....just to be sure you are not confused...thanks
                          Here is my Startmenu icon in case someone needs it
                            You can replace RUNQ by RUN ?
                              I gave up and instead created a new menu selection screen for my windows desktop stuff
                              All of my other screens have 'Windows' instead of 'Power' and open up my Windows Options screen except the 'Shutdown" screen...which has "Back To Main" instead of "Power', which returns me to the 'Welcome" screen...and the "Windows Options" screen is the only one that leads to the "Power" screen
                              I would...however....like to add level meters to the "welcome" screen(circled in white). How would i do that? I have not seen any skins that have level meters to use to edit from....thanks in advance
