flash skin preview
  • flash skin preview
    well.... i finally started getting the flash down to not using so much cpu
    preview of the skin is here
    and dont mind my flash skills.... i suck
    preview can be seen here
    www.hdesign1.dk/flash.php
    Food goes in here..... that's right ... mmmmm
    I have to say only one thing about this...
    Well Im having problems coming up with something to say, im speechless..
    ECELLENTE MI AMIGO
    You can still have something if you have nothing
      very nice...
      Download Skin For FrodoPlayer 1.0.9
        Flippin' wicked.
          first I thought what is the use of flash in a skin, now I'm starting to see the point. Looks very promising
          MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
          http://www.mp3car.com/vbulletin/showthread.php?t=31991
            that kicks arse :-)
            Follow me on Twitter
            http://www.FreeICE.co.uk
              Do I need 2.5Ghz CPU for smootnes of Flash Skin or PIII 1.2Ghz is enough?
              My Car:
              http://www.mp3car.com/vbulletin/showthread.php?t=39693
                www.hdesign1.dk/test.swf
                damn it looks good holistic
                det rykker for vildt......
                looking forward to have that skin i my car
                Mazda 323F
                Via 800 Mhz
                256 mb ram,120 GB hard drive
                Lilleput touchscreen, D-link USB radio,
                Griffin Powermate,
                Itune PW 70a powersupply, ITPS
                Windows XP Pro, RoadRunner
                Haicom HI-202S, Simacar navigation from Simatech
                  this should go on a fairly small system... been doing all i could to keep it down it cpu usage
                    holistic.. this flash stuff.. I've had a quick play, and managed to get things moving fading.. etc.. but how do you link it to a button. I understand the button needs to be on the skin, so RR knows to use it, but then what ? also do labels work ? a quick into would help loads. I know its a bit big, but its not being aimed at internet..
                    http://www.x-digital.addr.com/skin/flashintro.swf
                      well the button thingy is actually pretty complicated at first but as soon as u get the hang of it i becomes vey obviusly... it's kinda hard to explain but
                      the page where i learn all my flash stuff from is:
                      http://www.flashkit.com/tutorials/index.php
                      is a really usefull site
                      the reason it's hard to explain is that im still learning myself.. never done much flash.. only small things like website players etc..
                        There's a "sample" file with the brushmetal skin.. I've only learnt enough of flash to be able to do that.. you can use labels in flash and you can send commands from it.. to send commands you just need to run "fscommand("PLAY","")" for instance -- this is a script command in flash. RR will set variables in the flash script(s) for all labels you define in the .skin file (say TRACKNAME etc) how you read or display that variable from your scripts is up to you.. my sample file simply associates a dynamic text box with the variable and when RR sets the variable it gets displayed.
                        I wish I knew more to help you with.. but I did just re-test the sample and it works..
                        here's the bit of skin definitions that allows it to work:
                        /, Flash Sample
                        /, x y w h Movie
                        F01,107,530,068,048,"SAMPLE.SWF"
                        /, You MUST add labels for all information you intend to use in the flash movie (you don't have to show the labels)
                        L20,000,000,000,000,000,000,000,08,"Arial","TRACKN AME", ""
                        Ride Runner RR's Myspace
                          ok, been playing but not getting very far.. I have put a textbox and called it 'time' made it a target, and also set the text to dynamic. I have then entered the following code to the scene script..
                          onLoad () {
                          time.text = TIME;
                          durrr sussed out DYNAMIC text now.. lol
                          Now I would of thought this then would set the time text, and would show when its run.. hmm Guess not. I'm playing with swishmax at the mo, not got flash at the mo.
                            ok.. managed to get the text to display the contents of the label. just need to suss out how to get it to check it and update if needed
                            CdR
                            just realised where all this is being posted.. sorry will start a new thread. didnt mean to hijack this one, and totally go off topic
                              no prob.. we'll just rename it to the official flash thread
