Map Monkey control via RoadRunner
  • Map Monkey control via RoadRunner
    How can I show the menu seen in the photo below, by pressing a button in RoadRunner. I have tried the MM command with various options but I cannot seem to find anything that can be used to show this specific menu in MM.
    Can someone help out ?
    The road is long but we are getting there.
    You can't...
    The only thing you can do is to make a menu MM skin in RR that reproduce those commands with MM;RR buttons
    See my car and donate for spinning logos at www.ildena.it/carpc
      yeah.. MM just doesn't allow for "showing" that menu from it's skin.. so you either have to leave that button showing or make the whole menu in RR. You should be able to execute all of the menus options directly from RR.
      Ride Runner RR's Myspace
        Yes you can!
        my skin does it... just upgrade to the lateset MM patch and use the button "MM;Hotkey_CMD|FE_MENU_OPEN" You can use MM;ViewMode to bring up the other view menu...
        Roy
        2005 Range Rover 4.4
          cool... hard to keep up with all the patches there too.. hehe the last one I installed was for the ETR..
            I think the ETR is the latest
            Still having some problems with skinning it to be showign just the map, though....
            Roy
