Problem with RR and 640x480 skins.
  • Problem with RR and 640x480 skins.
    Hi all.
    I am having some problems with RR and the Brushed Metal skin in 640x480, it seems like the "buttons" arent calibrated. I have downloaded RR from http://guino.home.insightbb.com/rrbinary.htm, the Brushed Metal skin from http://rmc.pimpedwheels.com/BrushMetalBlue.zip and the 640x480 patch from http://www.dellanave.com/projects/ca...4_4_Update.zip.
    I replaced the files from BrushMetalBlue.zip with the ones from BrushMetal640_4_4_Update.zip but it still is all messed up, is there anything else i have to do to make it work? Tnx in advance, and tnx for a very good dashboard.
    Cheers
    - Bosse
    Originally posted by bosse
    Hi all.
    Cheers
    - Bosse
    I don't have any idea of what that patch you have has or does, but to get the skin in 640x480, you should do just the below:
    -Delete the current brushmetal skin you have "patched"
    -Download/Install the Brushmetal skin from my site
    -Open the GENERAL.INI file in the skin's folder and change the Showwidth and showheight to 640 and 480 respectively.
    -Load RR normally, it should display the skin in 640x480.
    You can do this with any skin. If you try to patch up skins with files of incorrect size, chances are you'll just screw the skin up.
    Ride Runner RR's Myspace
      The only option to make it look perfect in 640x480 is to resize all images say in photoshop (high quality) then edit all .skin files to set the correct areas.. I think that the update you got is basically for fixing the .skin files ONLY.. there's a whole thread on this, so I'd suggest you search on it a bit..
        Mine displays about 100pixels right and about 100pixels down from top left when I set show to values at 640x480 when using 800x600 skin and setting the top left corner as 0,0 or -100,-100 doesn't move it.
        I would like to move to 640x480 as my Lilli is super sharp at that res and poo at 800x600. And my Insight P4 doesn't do 800x480 - shock horror!
        Any ideas?
        My Nissan 200SX @ Silverstone
        NOW SADLY WRITTEN OFF!
        My Car's spec list + pics
        Stealth CarPC fab'ing...
          show me your general.ini and a screenshot. This has always worked dated far back to "remediacar". Chances are you just haven't set the screen SIZE correctly.. the positions should be 0,0 (typically).. for size you should have:
          showwidth=640
          showheight=480
            Hi Guino,
            general.ini contents (was called default_general.ini so changed it to try if that helped) and screeny as requested.
            [General]
            OriginalWidth =800
            OriginalHeight=600
            ShowWidth =640
            ShowHeight =480
            XPosition =0
            YPosition =0
            [Gamma]
            ApplyToVideo =False
            ApplyToVisu =False
            AutoSwitch =False
            DayTime =8:00:00 AM
            NightTime =6:00:00 PM
            GammaDayRed =1
            GammaDayGreen =0
            GammaDayBlue =0
            GammaNightRed =-40
            GammaNightGreen =-40
            GammaNightBlue =-40
              Hmmm, always aligns fine for me here and from what I can tell the general.ini appears ok
              Sounds as if the resolution is set to 800x600 on your PC, not 640x480. I think that may be the problem
                if that was the case it would display RR fine as its an 800x600 skin
                  honestly I can almost guarantee you that the general.ini file above is not for the skin you're using .. your screen shot proves it because the size of RR's skin is still 800x600 on it. There's one general.ini file for EACH skin -- and it MUST be in the skin's folder. I also recommend taking off the stupid "hide known extensions" options from your windows folders to be sure you have the right file name.
                    sorry Guino, you are right. sorted now thnx
                      Guino,
                      u rock... i had this problem and was pulling out my hair.. so simple... thanks u are the bomb!!!
                      http://www.hostunlim.com/kamlung/Cars//TL/sigfinal.jpg
