Beginner Skinner
  • Beginner Skinner
    Just trying to get this thing done
    Cannot get the FrodoSatelliteRadioX to start
    B53,308,545,104,90,"LOAD;XM2.SKIN;C:\Foto\Frodo.ex e;XM2","XM2"
    2001 S10 ZR2
    Chucks Skin - to old
    C:\Foto\Frodo.exe -- is this not misspelled ?
    also, are you sure XM2 is the correct window title? I was under the impression it (used to) be called 'FrodoSettelliteRadioX'..
    Ride Runner RR's Myspace
      I shorten it up
      This is what I have
      B60,309,545,104,90,"LOAD;XM2.SKIN;C:\Foto\Frodo.ex e;FrodoSatelliteRadioX","XM2"
      The problem is FrodoSatelliteRadioX will not start but the skin XM2 i made will come up
      2001 S10 ZR2
        Window title is "FrodoSatelliteRadioX"
        edit: oops, posted wrong first
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          Originally posted by Chuck
          I shorten it up
          This is what I have
          Well then I'm 99% sure that C:\Foto doesn't have a Frodo.exe file in it .. check or spelling or give me a screenshot of the folder with the file.. otherwise try running something simple like calc.exe to test your button.. there's also a high chance that if you did not define an application area in XM2.SKIN, the application will run BEHIND RR's skin.
            I know it has to be something dumb
            2001 S10 ZR2
              what about your xm2.skin file ? what do you have in it ?
                All it will do is open the skin and speak out the command but I am still trying.
                Even when I try the calc test command it will open the skin and calc then speak but the calc will not embbed like the apps calc will, but at least the calc will start
                Audio_Player.skin - part
                MEDIACAR Skin
                MEDIACAR F-CNS(800x600Stretched)"audioplayer"skinskinskinskin skinskinskinskinskin skin
                audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
                /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                B60,309,545,104,90,"LOAD;CALC.SKIN;C:\WINDOWS\syst em32\calc.exe;calc"
                B70,510,545,104,90,"TV","TV"
                B20,410,545,104,90,"VIDEO","VIDEO"
                B30,207,545,104,90,"RADIO","RADIO"
                B40,712,545,104,90,"GPS","GPS"
                calc.skin
                MEDIACAR Skin
                MEDIACAR F-CNS(800x600Stretched)"XM2"skinskinskinskinskinskin skinskinskinskinskinskinskin skin
                calc_empty.jpg,calc_OFF.jpg,calc_ON.jpg,calc_down. jpg
                B01,890,000,044,054,"CLOSE","Close"
                B02,960,000,044,054,"EXIT","Exit"
                /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
                L01,010,005,150,030,255,255,255,15,"Arial Narrow:B","TIME","Time"
                L03,320,6,450,50,255,245,000,22,"Tahoma:B","TRACKN AME","scroll-center"
                /, A, x, y, w, h, color;RGB
                A01,000,055,1024,570,000
                END
                2001 S10 ZR2
                  looks a little more solid now
                  2001 S10 ZR2
                    Well I installed rr in my truck today and love this thing but I have three issues.
                    1 I still cannot get Frodosatelliteradiox embedded with a button, just in apps.
                    2 Frodosatelliteradiox will not restart the XMPCR after hibernation unless I exit and restart Frodosatelliteradiox.
                    3 If I use the TV and try to go into hibernation it will not let me, with the ati all in wonder 128 software I had to exit it before it would let me.
                    Windows 2000
                    ATI All In Wonder Rage 128
                    FrodoSatelliteRadioX alpha 2
                    2001 S10 ZR2
                      Any chance I could get a copy of your skin complete with the Chevy bowtie emblem? Thanks!
                      2005 Black Chevy Impala
                        yes - when I have every thing working and complete.
                        2001 S10 ZR2
                          RR with Frodosatelliteradiox and copilot
                          I Wish I could figure out my above issues.
                          2001 S10 ZR2
                            Your embbeding issue is because of the following line:
                            It should be:
                            A01,000,055,1024,570,000,000,000
                            Now, is your skin at 1024x768 ? otherwise that 1024 should be matching the screen resolution or part of the application would be off the screen...
                            From what I've heard, FrodoXM doesn't work well with hibernation.. so you should close it before hibernating.. or make your hibernate button close it for you automatically ("CLOSEWINDOW"). Your TV card thingy is definitely your drivers preventing that from hapenning so again you should either switch off tv or make your hibernate button on the TV screen close the TV first (like "MAIN||HIBERNATE").
                              Thanks guino
                              To got the calc to work I had to add calc;
                              B60,309,545,104,90,"LOAD;CALC.SKIN;calc;C:\WINDOWS \system32\calc.exe;calc"
                              And now Frodosatelliteradiox works
                              B60,309,545,104,90,"LOAD;XM2.SKIN;XM;E:\Program Files\FrodoSatelliteRadioXblack\FrodoSatelliteRadi oX.exe;FrodoSatelliteRadioX"
                              So thanks again
                              Tomorrow I will work on the others
                              Ps I will have a donation for you this week
                              2001 S10 ZR2
