embedded visu
  • embedded visu
    i want embedded visualization in audio skin in a little windows ?
    is possible?
    guino help me
    My Home page
    Cartuper V2
    Epia M1000
    512Mb ram
    Hdd 40 Gb 2,5'
    Dvd recorder DL Panasonic
    Lilli 619 7' with TS
    SoundBalster Mp3+ USB
    Holux Gpslim236 usb + external antenna
    M1 Atx
    Remote control with girder
    somebody have a winamp plugin visualizzation a Spectrum analyzer 3d?
    same as the fast furious car?
    My Home page
    Cartuper V2
    Epia M1000
    512Mb ram
    Hdd 40 Gb 2,5'
    M1 Atx
      I'm no sure but I heard guino saying that you need to anable the plugin that you have in winamp in the RRconfig
      RexBruMet Skin for FrodoPlayer
      Nissan Aux-in MOD
      Originally posted by bgoodman
      We're an international forum, post in whatever langauge you like.
        You mean like this?
        Its not the cards you're dealt, its how you play the hand!
        Originally posted by ryuandwings
        Where can I get a roll of tin foil?
        I been looking for that all over the net, but I can't find it.
        Please help.
          Originally posted by J187
          You mean like this?
          Hey don't be a bad n00b and stop teasing the guy....... give him an answer!!!
          Nissan Aux-in MOD
            Huh? I dont' understand what you are trying to say
            Please help.
              You said "like this" but you didn't give him any info in how to do it.....
              Nissan Aux-in MOD
                OH. I wan't to make sure that's what he's taking about first. Hence the question - "Like this?" I don't wanna go off on some explaination if that's not what he's taking about.
                The way I did it.
                Make sure to properly select which plugin you are using in RRConfig. Milkdrop, AVS or Other. If you are using other and do not know the windows name, search for Winspector spy and use that.
                Once you've got matching plugin info in Winamp and RRConfig, you can edit how it is displayed by opening Audio_Player.Skin In Microsoft Word and looking for the line that begins with an "A". That line is the properties for the Vis. X, Y, W, H. change the X and Y Axis locatiosn and height and width to your preference. You must save that file and reload the skin to take effect.
                Note: Some visualizations might have predetermined max and min W and H values - this can be frustrating.
                Good luck.
                Please help.
                  @J187 - Well put.
                  As long as the plugin is selected in winamp and its window name is set in RRConfig, it should work. Some plugins simply don't let you resize them while others will not let you make them any smaller than a certain size.
                  @corsab
                  I have not yet found a "simple" spectrum plugin that is flexible in size or style. I am pretty sure there's a lot of prople looking for that. The best thing would be to find an AVS style to add to winamp -- the ones I've seen are not resizeble, and others are only full-screen.
                  Ride Runner RR's Myspace
                    So my answer that no apply
                    No body likes me!!!! why???
                    Just kiding just trying to help in a front end that I don't use.
                    Thanatos
                    Nissan Aux-in MOD
                      Thanatos
                      That's commendable. You helped, err, a little bit. You still get a star for your forehead.
                      @ corsab
                      You should let us know if it works out for you.
                      Please help.
                        Take a look here:
                        http://www.geocities.com/SiliconValley/Peaks/9546/
                          This is one of those "non-resizable" ones I speak of.. it has a height property but no "width property". RR is able to resize the width but you have to set the height in the plugin manually -- this works better than other plugins but if the vis space is different from skin to skin, chances are the vis won't look right on all skins.
                            Hi there
                            Just a simple question, why not ask the programmer if this vis could be made resizable? As i am not a programmer i do not know if this is possible, but someone could ask the author of this vis.
                            Would be a nice feature for RR
                            THX
                            Chaos
                              If you have access to the author, that is a good idea. I know for the vis that I liked, I tried to contract the author but the given e-mail address was not valid.
                              Please help.
