Another question: "Night skin" in Roadrunner
  • Another question: "Night skin" in Roadrunner
    Is there any "time config" for enabling this option?
    I've selected a "night skin", but RR never changes skin by itself. What am I doing wrong?
    P.S.: I've but I didn't found anything 'bout it.
    Sorry my poor English! I've learned more English from Internet that from school.
    Well, I think I've made my question in a wrong place (skins)... Sorry!!!
      having a look in the general.ini in the skin folder which u want to use
      OriginalWidth=800
      OriginalHeight=600
      ShowWidth=800
      ShowHeight=600
      XPosition=0
      YPosition=0
      ApplyToVideo=False
      ApplyToVisu=False
      AutoSwitch=False
      DayTime=8:00:00 AM
      NightTime=6:00:00 PM
      GammaDayRed=0
      GammaDayGreen=0
      GammaDayBlue=0
      GammaNightRed=-40
      GammaNightGreen=-40
      GammaNightBlue=-40
      change the autoswitch to true and edit the times you want in
      CdR
      Follow me on Twitter
      http://www.FreeICE.co.uk
        Thanks, CDR!!
        P.S.: Congratulations for your work.
          Currently RR doesn't support the audo-switch of gamma. The values in general.ini will be ignored for now. This is a very easy feature to add but I don't want to add it without adding support to change this stuff in RRConfg (and that is what takes time).
          Ride Runner RR's Myspace
            OK, Guino. Thank U too!!!
              is it possible to implement a timecheck for this, that checks and autoswitches every minute ?
              so that switching the skins is also working when coming out of hibernate or standby ?
              time for the sig:
              '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
                When I do implement it, it will check the time when start and resuming then set the gamma to the appropriate day/night setting.
                  Sorry to bring back an old thread, but I can't get RR to change skins. I've edited the general.ini files for the skins and the RR.ini
                  text added to RR.ini
                  autoskin=true
                  daystart=0800
                  nightstart=1800
                  text from BMV2 general.ini
                  AutoSwitch=True
                  DayTime=8:00:00 AM
                  I have BAV set as my default skin and BMV set as my night skin in RRConfig.
                    As guino said above it isnt supported (thats what I understand) unless it has been added...
                    Roy
                    2005 Range Rover 4.4
                      Well that's why I asked as he updates the program at least once a week and that post of his was 3 months ago.
                        still isn't ...
                          cool
                          thanks for the response
                            Use GammaControl
                            PowerVoice v1 | NaviVoice Source
                            GammaControl v2.4
                            SKINbedder v3
                            1995 Lexus SC300
                              i knew you were going to say that.
                              I did play with it a bit when it changed to my night skin it would automatically choose the darkest setting. If I hit the gamma button again to lighten it up it would change back to the day skin. I'm sure it's a configuration problem on my end I was being lazy and didn't mess with it more than that.
