Error 13: Type mismatch
  • Error 13: Type mismatch
    Hey guys. I am getting this error with my new skin, and cannot figuire out why.
    I have the latest binaries of both RR & RRSkinEditor.
    Searches reveal this question was asked once before with no answer.
    I'm making a new skin. If I start with BAV2 and then switch to my skin, no problems. If I close RR, then reopen it with my skin, I get the error.
    Any clues?
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Post your menu.skin file... likely you have an invalid value or wrong definition on the file.
    Ride Runner RR's Myspace
      Thanks Guino! Your front end rocks, and I'm having a ball playing with it!
      It's very simple to start...
      Code:
      MEDIACAR Skin
      MEDIACAR menu Skin
      /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
      B11,629,521,60,70,"EXIT","Exit"
      B08,369,521,60,70,"EXIT","Exit"
      B14,729,181,60,70,"PHOCO",""
      B15,729,96,60,70,"EJECT",""
      B13,729,266,60,70,"LAUNCH",""
      B12,729,356,60,70,"EJECT",""
      B10,542,521,60,70,"MINIMIZE",""
      B09,459,521,60,70,"QUIT",""
      B07,199,521,60,70,"GAMMA",""
      B06,114,521,60,70,"MUTE",""
      B05,14,436,60,70,"EJECT",""
      B02,14,179,60,70,"GPS",""
      B04,14,355,60,70,"VIDEO",""
      B03,14,265,60,70,"AUDIO",""
      B01,14,95,60,70,"XM",""
      /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
      L01,9,16,73,25,055,055,055,12,"LCD Display Grid","TIME","Time"
      L02,9,40,73,25,055,055,055,16,"Arial Narrow:B","DATE","Date"
      /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
      S,285,200,400,200,0,255,0,0,84,227,255,0,0,255,255,0,,14,"Arial"
      /, F, x, y, w, h, Movie name
      F,136,100,105,129,"XMlogo.swf"
      L,285,135,400,40,,,,,,"TAGARTIST",
      L,285,95,400,40,,,,,,"TRACKNAME",
      END
        Viscouse,
        Your "TAGARTIST" and "TRACKNAME" labels at the bottom need to have a color and font defined or they need to be moved under the other labels like so:
        Beer is proof that God loves us and wants us to be happy Benjamin Franklin
          It is a very bad practice to ommit information from object definitions..
          Those three lines are most likely your problem:
          S,285,200,400,200,0,255,0,0,84,227,255,0,0,255,255 ,0,,14,"Arial"
          The S definition you should have either TRUE or FALSE before the font size (or you may run into trouble).
          The L definitions should have the propper font color, size and name setup (or you may run into trouble). If you wish to hide the label, simply set W and H to 0 (ZERO), but all fields must be propperly filled up or I have no way to predict the results. It is also a bad practice to leave the ToolTip blank (you should set it to at least "").
            Duly noted.
            I shall clean up & see if the error disappears.
            Thanks for the input guys. I do appreciate it. Especially before I finish coding all the pages!
              Thanks guys, that did the trick.
              I don't know which in general, I just supposed I need to be a little cleaner.
                Yeah, your problem is most definitley within the 4 straight empty ,,.
                Its not the cards you're dealt, its how you play the hand!
                Originally posted by ryuandwings
                Where can I get a roll of tin foil?
                I been looking for that all over the net, but I can't find it.
                Please help.
