Is it possible to....
  • Is it possible to....
    change skins:
    a. after a set amount of time (ie 10 seconds)
    b. on any mouseclick or mousemovement
    basically i wanna have skins load similar to the way the video controls and mappoint controls pop-up. It wouldnt be all skins, just specific ones.
    Live mp3Car Facebook Chat
    It's possible to do this using the MENU command along with the IDLE event.. it's a bit complex and you'd have to make a full size menu (and cut off the areas you don't use), but should work .. the limitation is that the screen below it would not be accesible while the menu is up.
    Ride Runner RR's Myspace
      yea i've been reading up on the idle event and can see using the menu command to make it work, but can you define which skins the idle event would apply to? Basically what i'm tryin to do is make my gps skin go full screen after 10 secs of no movements. I have both the reg. size skin and full size skin already made but how do i tell rr to only use the idle event when on the reg. size gps skin?
        ok i have a button in my skin doing what i want it to do
        Here's that button code
        Code:
        B,662,76,138,52,"RunQ;C:\Program Files\Close Zoom\Close zoom.exe||MENU;external_gps_fs.skin||RUN;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||RunQ;C:\Program Files\iGzoomFS\iGzoom.exe",
        I've also added the IDL timer to the skin for 10 seconds
        Code:
        /, IDL, Seconds
        IDL,10
        And this is my entry in exectbl.ini
        Code:
        "IDL","RunQ;C:\Program Files\Close Zoom\Close zoom.exe||MENU;external_gps_fs.skin||RUN;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||RunQ;C:\Program Files\iGzoomFS\iGzoom.exe",External_GPS.skin
        button works fine but the idle event does nothing. Whats the deal?
          it should be "IDLE" in exectbl (not "IDL").. and IDL on the .skin file (this is correct)
            gracias.. works great!
              Is it possible to have more than one IDLE in the Exectbl.ini? Like for having different IDL functions on different screens?
              Project BioHazardous Material || BioHazard . LU
              ████████████████░░░░ CAR
              ████████████░░░░░░░░ LAPTOP
              █████████████░░░░░░░ FRONT-END SKIN
              ██████████████░░░░░░ PERIPHERALS
              ░░░░░░░░░░░░░░░░░░░░ INTEGRATION
                sure, place the IDLs in the .skin files then do something like:
                "IDLE","COMMAND",audio_player.skin
                "IDLE","COMMAND",audio_browser.skin
                etc.
                  cool thanks,
                  I am heavily amazed about what this program can do!!
