How do you embed an application which needs a file as a parameter?
  • How do you embed an application which needs a file as a parameter?
    I'm looking to add items from the Control Panel into my skin. To do this I need to be able to run, for example, "c:\windows\system32\control.exe sysdn.cpl" . I need control.exe to open sysdn.cpl . There needs to be a SPACE or a forward slash ( / ) before the.cpl file. I've tried putting this directly in as the command e.g:
    "LOAD;SYSTEM.skin;System Properties;c:\windows\system32\control.exe sysdn.cpl;!32770!System Properties"
    or
    "LOAD;SYSTEM.skin;System Properties;c:\windows\system32\control.exe /sysdn.cpl;!32770!System Properties"
    but it doesn't work. The only work around I can see that works at the moment is using batch files to open the windows but its messy as a cmd prompt windows opens aswell.
    Any help is appreciated.
    LLOYDY
    - My 2003 E46 BMW 318Ci Completed Install
    - Simplistique RoadRunner skin download
    - Team QuidGrid.com on the 2006 Mongol Rally
    try
    Code:
    LOAD;SYSTEM.skin;System Properties;c:\windows\system32\control.exe" "/sysdn.cpl;!32770!System Properties
    OR
    Code:
    LOAD;SYSTEM.skin;System Properties;c:\windows\system32\control.exe|/sysdn.cpl;!32770!System Properties
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
      not sure how you would run a control panel item, but to run a file as a parameter it would look like this
      "RUN;DIR\DIR\program.exe|file.doc;windowtitle"
      beer replenishment fund
      mp3car live search
        Excellent! THANK YOU THANK YOU THANK YOU!
        Been racking my brain all morning! Knew I seen it somewhere before. The ol' pole ( | ) does the job.
        Thank you for the VERY fast responses! Perfect!
        LLOYDY
