Skinning Help
  • Skinning Help
    Hi, I tried reading the tutorial and topics, its either it did not sink in or i did not find the answer. for example, the alpine skin, how do i direct the picture viewer button to point to a specific directory? or the games button, how do i direct it when pressed to go to a specific directory or run an application? and what if i dont want the word games in there and i want to replace to like obd-ii, how do i change it and point it to the right application? please help. thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    I use the "LOAD" command.
    example:
    Make a skin for the app You would like to run. ( say, OBDII.skin)
    Should include OBDII_OFF.jpg, OBDII_ON.jpg, OBDII_DOWN.jpg, OBDII_EMPTY.jpg. (atleast the OFF.jpg and ON.jpg)
    Then assign a button on the Menu to perform that function.
    B,523,418,151,56,"LOAD;OBDII.skin",
    You can also use the "LAUNCH" command. But this is how I usually do it.
    Hope that helps.
      The best thing I found that helps with most of my skinning questions is looking at other skins or learning what to search for.
        I dont do much skinning but when i need small changes i do
        P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
          True, You can just open a .skin file in notepad and see how it is constructed.
            thanks for the reply, where i get lost is, where is the language that instructs the skin to open the particular program, say the obd program, shouldnt there be a path like crogram files.... to direct the button? thanks again for the help
            7" Lilliput
            Opus 150
            mini itx 1Ghz
            1GB sdram
            97 Prelude
              In that case it should look something like this
              B,638,139,160,44,"RUN;C:\Program Files\Road Runner\CDRIP\CDRip.exe","RipCD"
