LOADLIST Button
  • LOADLIST Button
    Hi guys,
    I have been trying to get a skin to display the available saved playlists, and load a playlist selected from this list, but I am having no luck. I know I can use the LOADLIST command, but I can't seem to display the playlist directory.
    Any pointers, help appreciated.
    regards
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    You can make a secondary browse screen -- using the SD definition to point it to your playlist directory, then RR should show the playlists in a list like the file browser and you should be able to use "SELECT" to load it. Should really be simple.
    Ride Runner RR's Myspace
      Thanks Guino,
      I will give it a try.
      cheers
      KPJUK
        Thanks Guino,
        I have got it working as you suggested, thanks for the input. I couldn't get the LOADLIST command to do anything though, but the SELECT command worked a treat.
        I am sure I am not alone in thanking you for your development of RR, and for putting up with L Platers like me !
        KPJUK
