Beta Release Black Vinyl on Aluminium
  • Beta Release Black Vinyl on Aluminium
    Beta Release v4 22nd July 2006
    I have finally fitted my carPC into the car, and have been ironing out some of the issues with it. So I have only added a few items. Not had much feedback. . . . . is there anybody out there ?
    Download RR Skin from here http://www.stonewaresystems.co.uk/BlackAl-betav4.rar
    Download Rainlendar Skin from here http://www.stonewaresystems.co.uk/Rain-BVOA.rar
    Unzip to your skin directory and use rrconfig to point to this skin.
    I have also started to skin Rainlendar to integrate into RR. To use this, you need to download and install Rainlendar. I have installed it into the Road Runner main directory. Rainlendar has a skins folder, and you need to copy my BVOA skin folder into the Rainlendar\skins directory. Then fire up Rainlendar, right click on the current skin and navigate to the skins option, and select BVOA.
    To install the matching BVOA skinget Rainlendar working in this skin, you need to add two files and a directory into the \Road Runner\LAUNCH directory.
    First create a directory C:\Road Runner\LAUNCH\Rainlendar, and then using Notepad, copy these lines below to Rainlendar.ini
    [GENERAL]
    PATH = C:\Road Runner\Rainlendar-0.22\Rainlendar.exe
    TryEmbeddedTimeOut = 5
    WindowSearchString=Rainlendar
    (Please note that your Rainlendar install directory may be named differently to this.) You also need to add a suitable Rainlendar.jpg to the directory.
    Weather images are in the weather file c:\road runner\weather, and the weather directory included needs to be installed
    Fonts
    Fonts have been changed to use the standard windows fonts
    Arial
    Verdana
    Wingdings3
    Webdings
    Changes
    Initial Menu screen changed to include 5 Flash Clocks (respect to Happpyg) These are:-
    Speedo
    CPU
    CPU Temp (based on Speedfan)
    Heading
    Sat count
    You may need to use Xport3 or something similar to multiplex the data to pass to the clocks, as well as support your GPS Application.
    Top left (date/time) is hidden VISU button on all screens
    Top Right (Song Details) is exit button (Need to press for 2 secs to operate)
    Menu button (bottom left) uses a jpg image (90 x 60) called menu.jpg. This can be changed to any image of your choice.
    The OSK keyboard has now changed to use the Original Virtual Keyboard from SilentAdmirer, skinned to match BVOA
    Added Rainlendar skins in Launch Folder
    Fixed Day/Night Button on second menu screen, the button area had been moved down the screen.
    Changed wbrowser.skin to www.skin in order to get the OSK working correctly.
    Beta Release v3 18th May 2006
    Download from Here
    Removed Windows logo (Menu button) from skins and added as an image file to give more flexibility to use whatever image suits you on the skin. The image size I use is 90(h) x 60(w), and is called menu.gif. The easiest way to change this is to make a gif image of 90 x 60, and replace menu.gif in the skin directory.
    I have been trying to get this thing fitted into the car with limited success, so not much progress on the outstanding skins yet.
    I still haven't had much feedback on the skin yet, so assume it works as expected ? I thinking of using the timer to control the visualisation from the main skins after a set amount of time. This will be reset by hitting the visualisation button (top right of the screen).
    Any suggestions or bugs please post me a reply.
    cheers KPJUK
    Beta Release v2 13th May 2006
    Download from here
    Added Launch screen
    Added Playlist Load screen
    Changed fonts to use only Base Windows fonts
    (Arial Century Gothic, Verdana and Tahoma, Webdings and Wingdings 3)
    Bugs
    Can't get Pink Transparency working properly on Playlist Load screen!
    Time for skin number two !
    KPJ Grey skin didn't give enough contrast in strong daylight in the car, works great on the bench, but thats no use to no-one !
    So here is a re-designed skin for beta release, all comments welcome.
    Beta Release - 11th May 2006
    Download from here
    Screens so far:
    Main
    Main 2
    Audio Player
    Audio Browser
    External GPS (Infomap Navigator)
    Web Browser
    Skin Browser
    DVD Player
    Weather 1 day
    Weather 5 days
    Day/night (Gamma only)
    CPU Stats
    Mixer
    Launch (Apps)
    Todo
    Radio - for a Dlink DRU
    TV - for an Artec T1
    Calendar / Event / Alarm / Todo
    Any other suggestions . . . . . .
    I guess the flash in the middle of Menu 2 is a bit pretentious, to change it, just replace the file logo.swf with a swf file of your choice, plenty are available.
    Enjoy
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    More screens
    More screen shots
      Weather screenshots
      Here are the weather screenshots
        Launch Screen & Playlist Load screenshot
          fantastic skin ^_^
          My car install
            Thanks Pierchi,
            I am glad you like it, btw the date/time in top left is a hidden button to exit the skin.
            cheers
            KPJUK
              v3 Ready
              v3 ready for download see first post for details.
                v4 is ready for release. I would appreciate some / any feedback !
                see first post for details of install and changes
                cheers
                KPJUK
                  I really like this skin because it's easy to read and the main menu has plenty of configurable buttons.
                  One change I'd like to see is to add an online indicator. Personally I'd rather see that then cpu usage, but here's an idea. You have the total track time, then the current track time displayed in the middle of the slider counting up to the track time. Why not put the total track time in the middle of the slider instead of current track time, so it shows what the bar graph is heading toward, then put an online indicator where the total track time is displayed now? Just a thought.
                  I'm about to go on vacation but I'll try to give this skin a good test when I get back in a couple of weeks. I use MapPoint so I can use the external GPS skin for that, I think. I also use PhoCo so I'd like to see a skin for that, but I know PhoCo support is tricky.
                  Nice work and I hope you continue it.
                  Cheers,
                  Z
                  Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
                    Trying the gps screen the full scrn, + , - buttons don't work on my system. The screen flashes and stays as it was.
                    I have infomap navigator 4.4
                      Thanks Zogg for the input. I do aim on keeping this skin up to date, and will get around to some of the gaps when time allows. I haven't done an online indicator, as I won't be using the web in the car, but I can have a look to see if I can get one working, as long as you are prepared to test it.
                      I don't use Phoco yet, but will in the future. I have been helping Griff1 with his Phoco ski, and can "mirror" that style in this skin format as a starter. I have only just come back from a week in Ibiza this morning, so I am not quite with it at the moment, but I hope your holiday goes well.
                      Clarkie, I can see your problem. Choices to fix the buttons are as follows:
                      click anywhere in the Navigator window, before you use the buttons (crap answer I know !)
                      Change the three button definitions in the External_GPS.skin file to
                      B03,557,-2,64,86,"ACTIVATE;Navigator||SENDKEY;{F6}","Zoom In"
                      B04,617,-3,63,86,"ACTIVATE;Navigator||SENDKEY;{F5}","Zoom In"
                      B05,497,-1,64,86,"ACTIVATE;Navigator||SENDKEY;%V{RIGHT}I%V{ RIGHT}O","Fullscreen Toggle"
                      I was playing around with GETFOCUS and the ACTIVATE commands to get these buttons to work properly. Navigator unfortunately names all of its windows QWidget, so it is a pain getting the right window to focus.
                      I was going to have a play with the OCX files, but you need the Plus version to use this, and I only have the European edition. I am going to have a look at doing a GPS Menu for some of the more useful Navigator options. If you have any requests, let me know and I will see if I can get them working.
                      If you get stuck, PM me your email address, and I will send you the updated skin file, but it will be tomorrow now, I need to do some stuff to keep her in doors sweet now where all up !
                      Cheers M8
                      KPJUK
